Question about HTC S620 Smartphone
My HTC S620 wont power up. I turned it off last night and tried to power it up this morning but nothing. I know it has plenty of battery life and wont turn on even with the charger attached. Any help?
  • 729 Answers
Have you press the button for about 3-5 seconds and are you sure that it is the right button ??
Posted on Dec 12, 2009
Tip
I have an HTC s640 and it just stopped charging the last time the battery ran...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Apr 04, 2010 | T-Mobile MDA
Parked car last night no problems. this morning will not even crank, plenty of battery but the lights won't even dim when I turn the key nothing at all.
If you don't mind troubleshooting, I recommend you try jumping the solenoid. This will tell you if it's the starter versus the switch/wiring.
Please see my tip at http://www.fixya.com/cars/r5821173-doesnt_car_start_gasoline_engines and let me know if you have questions.
Sep 24, 2010 | 2001 Chrysler Sebring
Phone won't Turn On!!!
If just removing the battery dont work... Remove the sim and battery then put the battery back without the sim. Try hard reset now. Tmobile wanted to send me a new phone til I figured this out. They now have this solution in their tech notes.
Mar 14, 2009 | HTC G1
Cannot turn off the alarm
The problem appears to have resolved itself. The oly changes I made to the smartphone was to power it off and insert 16GB mini SD memory card. Since powering back up I have not had the alarm warning.
Nov 28, 2008 | HTC S620 Smartphone
My HTC S620 stays on second start screen
Hello, These methods have been confirmed on my phone with both T-Mobile's ROM and Excalibur (S620 original ROM) Remove any memory cards before starting this process.
With OS:
1. Select Start
2. Select Accessories
3. Clear Storage
4. Type in 1234
5. Select Yes
Without OS:
Turn the hand-held off, hold the two soft keys (the dashes to the left and right of the phone buttons) hold the power button for 1-2 seconds and then release the soft keys. It should prompt you to clear storage. The “send” button is considered as the green phone button.
Let us know if you have any other questions. If this information was helpful, please take a moment to rate the solution. Thank you.
Nov 28, 2007 | HTC S620 Smartphone
Random shut offs
Sounds like a faulty battery, these phones arent known to have very good battery life even when they work properly
Nov 22, 2007 | HTC S620 Smartphone
HTC S620 Smartphone Logo
320 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
