Question about New World 50GSO Gas Kitchen Range
I can't make my oven to work
I can hear the gas when i switch it on, but when I put the light/fire next to where i think the gas is coming out from, nothing happens....I don't know what to do
  • Anonymous Dec 24, 2008
    I light the oven, the gas comes on and then it goes out after a few mins. HELP
I think we have this sorted. Thanks for helping. We just got the cooker two days ago and this is the first we tried the oven. We held Number 8 in for 2 mins to make sure it was working and that solved the problem.
Thanks to the original poster for the solution.
Merry Christmas.
xxx
Posted on Dec 24, 2008
  • 27 Answers
That model has an electric ignition ? you turn the oven to full (8), keep the dial pressed in & press the ignition switch.
You should hear the clicking & if you look at the bottom of your oven you should see a flame through a small round hole.
You have to keep the dial(not the ignition, the dial(8)) pressed in for about 30 seconds for the thermocouple to warm up before you let it go else the flame will just go out. ( if the thermocouple isn't warm enough it will cu off the gas, safety incase of loss of flame or accidental use of oven)
Posted on May 27, 2008
6ya staff
SOURCE:
My 7060 oven won't light. The electric igniter comes on but no gas.
an you hear the oven gas igniters firing? If not maybe there is no power to the oven. Not sure of your oven, but does it have an electric fan and if so, does it work? This should prove that there is power to the oven
What is the model number of your gas stove (oven/cooktop)?
Does your oven light work? If not does your oven have a separate power cord, i.e are there two power cords one for the cooktop and one for the oven?If so have you checked that the power outlet for the oven cord is working?
Mar 27, 2018 | Ovens
Heating is not firing up
check burner tubes for clogs and gas valve
Sep 27, 2017 | Water Heaters
Water heater is not firing up
Faulty gas valve,contact a gas safe engineer to replace.
Heater is not firing up
The igniter may need replacing.
Sep 27, 2017 | Heating & Cooling
My oven a GE XL44 worked well last Thanksgiving but the next day the oven won't light up. I opened up the oven and could see the pilot light was on but the bar where the fire comes out has no fire in it....
you have a bad ignitor.even though it's glowing doesn't mean anything.it works with amps.3.2 amps opens the gas valve and then it ignites.
Jan 20, 2011 | Ovens
The fan is working bt the oven isnt getting hot
I assume you have already checked the gas supply by turning on a burner on top.
Do you smell gas when the oven first tries to light? If the flame sensor isn't picking up a fire on the oven burner within a few seconds after the igniter is supposed to start firing, it will shut off the gas valve. The first thing to check is the oven igniter. Can you hear it sparking (repeated snapping sound until main flame starts)? The sound may be drowned out by the fan, so hearing it would only verify that it's making sparks; not hearing it doesn't tell you anything unless you were able to hear it before the problem started. If you had a major spill in the oven recently, it's possible some residue made its way to the igniter or pilot flame tube and is gumming up the works.
The next items to check would be the oven gas valve and thermostat.
Nov 12, 2010 | DeLonghi DEFSGG36 Gas Kitchen Range
My oven works fine it just doesn't heat-up. I can hear ignition clicking but no fire from burners. A technican told me to purge the union above gas to get rid of air in the line. Thanks Louis
Personally I wouldn't describe an oven that doesn't heat up as working fine. You shouldn't have any air in your gas line unless this is the first time firing the oven, in either case the air in the gas line would work its way out eventually and the oven would light on its own.
Check to see if your ignitor is glowing before you hear the clicking, if the ignitor isn't glowing it needs to be replaced and is fairly easy to do so. If your ignitor is glowing you should check to make sure you are getting gas to the burner. The only way I would recommend checking this is with your nose, do you smell gas when the gas valve clicks? If you do then something is wrong with the burner, either dirty or the exhaust is too strong, or even gas pressure too low. If you don't smell any gas that doesn't necessarily mean no gas is coming out, at this point you should call a authorized service provider to take it over from here.
Nov 03, 2010 | Baxter BXA2G Stainless Steel Gas Single...
GAS RANGE OVEN CAN'T SEE THE MODEL ON THIS SITE JPBC????
Sounds like the sparker in the oven isn't correctly installed, if you hear gas try and light it with a lighter, (WATCH OUT FOR YOUR FACE)
Aug 07, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
New World 50GSO Gas Kitchen Range Logo
371 people viewed this question
Top New World Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Robert Rankin
Are you a New World Kitchen Range Expert? Answer questions, earn points and help others
