Question about Sony VAIO VGN-CS215J/W Notebook
A/v touch sensor does not work - Sony VAIO VGN-CS215J/W Notebook
    Novelist:
  • 192 Answers
  1. Click the Start button, and then click on Computer .
  2. In the Computer window, under Hard Disk Drives , double-click on (C:) .
  3. Double-click the Windows folder.
  4. Double-click the DRIVERS folder.
  5. Double-click the .EXE folder.
  6. Double-click the Pointing Driver (Synaptics) folder.
  7. Double-click on the setup or setup.exe icon.
  8. Follow the Synaptics Pointing Driver Installation wizard instructions to install the driver.
Downloading and installing the Synaptics driver update available through the Drivers & Software link on this page will also resolve this issue.
Download the Driver here
Posted on Aug 05, 2010
My performa dryer is leaving burn marks on clothes. The marks (pattern) is from the covered opening on the back of the dryer. Any idea what could cause this or how to fix it?
You have a bad sensor that is not sensing when to turn the heat off, it just heats full on the whole time, you can check sensor with the power off and a meter on continuity, the sensors are located on the heating tube that the coils are inside. the sensors should have shut your dryer down but maybe your sensor is stuck closed with would make it work and not tell the dryer when to turn off heat, or your wires are touching eachother where the sensor is located, so you accidently or defectively the wires are connected and not running through the sensor
check the wires and replace the sensors. there are a few sensors on my dryer, they are small devices that sit on the exhaust tube and the heating coil can, simply use your probes to check for continuity on the two lead wires to the sensor, and make sure the wires are seperated and not touching eachother where they plug in to the sensor, one may have gotten bent over and now you have a jumper. same as if you pull the wires off the sensor and touch them together. I have a bad sensor and touched my wires together and now my dryer works, but is dangerous, and needs monitored until you get a new sensor in place and hook up correctly
Jan 01, 2013 | Dryers
Vgn-cs26g touch sensor not working
my vaio VGN-CS26G' touch sensor panel doesn't work after install Windows 7
please help the basic is Windows Vista after i change it in to Windows 7 touch sensor panel doesn't work
Aug 10, 2012 | Computers & Internet
Touch screen sensor is not working. plzzzzz help me
Hi bonnie1786,
Have a nice day
There are two major causes of malfunctioning of touch screen,the phone fell on a hard object or in water which could damage the sensor board , or either the sensor board is weak and needs to be calibrated or replaced. The sensor board is what makes the touches read on the main board of the phone.
You have to calibrate the screen, but since it is not responding to touch, then it means you have to replace the sensor board of your phone and it will be alright.
Hope it helps.
Thank you for using fixya.
Adieh
Sep 14, 2011 | Cell Phones
Touch screen not working
Hello there,
If the touch screen of your phone is not working, then it means there is a problem somewhere, the problem is that the sensor board is weak and need to be replaced. The sensor board is what makes the touches read on the main board of the phone.
You will have to calibrate the screen, but since it is not responding to touch, then it means you will have to replace the sensor board of the phone.
Have the sensor board replaced and the phone will be okay.
Caseytech
Jul 06, 2011 | Samsung B3410 Cell Phone
The touchscreen on my pantech pursuit isnt working! Have tried charging the phone, turning it off for long period of time then turning it back on. taking out the batter and putting it back in. Nothing is...
sir the touching sensor of your cellphone has been failed give to the related service center for servicing the touching sensor device [or] the will change the new touching sensor device to solve the problem.............
Nov 24, 2010 | AT&T Cell Phones
My samsung S5233A mobile the touch screen doesnot work? Any solution to this is most welcomed Suddenly my touch screen is not responding. So i m unable to go to menu and use applications
sir the touching sensor of your cellphone has been failed. service your cellphone in the samsung service center to change the touching sensor device [or] the will install any new softwares to work the touching sensor.............
Nov 22, 2010 | Samsung Star GT-S5233 Cell Phone
Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Jan 13, 2010 | Maytag MER5730 Electric Kitchen Range
Sensor strip not working
the touch sensor wasnt made that sensitive that much so you may have to try harder to get it to work if theres still a probelm download firmware.
Jul 24, 2008 | Creative Labs Zen Touch MP3 Player
Touch sensor problem
hi first thing first nice story about a button couldnt understand what was the point but at last got it any way it appers that your device has a problem of earthing (ground) try connecting a copper wire to the metal surface of the device to antoher metal surface and see if the problem dissolves more then that needs a technician good luck
Feb 19, 2006 | Pioneer NS-DV88 System
Sony VAIO VGN-CS215J/W Notebook Logo
1,069 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
