Question about Viking VGIC485-6G Gas Kitchen Range
Replacing PB010036 Bake / Broil Thermostat Viking
Replacing: PB010036 Bake / Broil Thermostat Viking
in a Viking VGIC365-6B
Is there an assembly drawing of the oven/broil control?
I need to replace the oven thermostat and in order to do that
the oven electrical control control switch needs to be taken apart.
  • 30 Answers
You do not need to take apart any switches, all you need - unplug it from power, open front panel (2 screw on each side) remove all knobs, there is 3 more screws behind them). unscrew thermostat 2 screws behind knob. open top part of stove, remove grates and cover. you will see wires to thermostat unplug them and plug one by one to new thermostat. remove old thermostat from inside the oven (it has bracket inside). put the new one. close everything back.
appliancesrepairla.com - viking repair LA
Posted on Jul 02, 2010
  • evmc Sep 30, 2010
    This was good advice, but I found out that you must also remove the two bottom screws from the burner controls on either side of the oven control, because these screws hold the front panel to the burner controls. I did not need to remove the three screws behind the front panel. Would appreciate any more tips for routing and inserting the thermostat thru the hole into the oven. Thank you
  • Brent Poole Oct 05, 2016
    this was perfect advice. I didn't even have to remove the front panel. I was able to access through the top. Thank you so much for the help!
Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
What is the best setting for my viking on a 14 pound turkey, bake or do i use the convection broil?
Use the regular bake setting.... run the oven at 350.... the 14 lb. bird will take about 4-5 hours.....convection moves air and can tend to dry out the bird...
heatman101
Nov 25, 2010 | Viking 30" Professional Select Built-in...
One of the oven ignitors does not work
Most likely replacing the ignitor will fix it. I usually replace Viking ignitors with Maytag ones, part number 12400035 (you'll need splice wires and use included wire nuts to connect those, though). Those have a little shorter base, which does not affect anything. Replace both bake ignitors if you can, otherwise, one of the burners will ignite slower and shut off faster, resulting in uneven bake.
Jul 17, 2010 | Viking VGSC306-4B Gas Kitchen Range
My oven wont heat up?
Hello there:
first chevck to see if the broil feature will work but if both the broil and bake feature does not work meaning it will not heat up if you have selected either the bake or broil follow these solutions that i have provided for you .
It won't bake or broil If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Jul 13, 2010 | Hotpoint SY36 Style Line Stainless Steel...
The oven function (broil, bake, etc) knob does not light
Open high limit or bad relay most likely.
The relays are located on the back side.
The limit I am not sure where it is stashed.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 08, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Whrilpool GR450LXHB2- The stovetop works, but the
It won't bake or broilIf neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
It won't broil Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 25, 2009 | Ovens
Viking oven broil keeps on
it is designed to preheat this way. after the unit cycles the red indicator light off the first time than both elements turn off. when it calls for heat again only the bake elements comes on. makes the preheating work faster.
May 05, 2008 | Viking 30" Professional Select Built-in...
Viking broil igniter does not glow, works ok on bake cycle
There are three separate igniters, one starts the broiler and the other two are bake ingnitors left and right.
So the bake circuits ignitors work and the broil doesn't
Replace the ignitor
The part number for all of them is PB040001
May 02, 2008 | Viking Kitchen Ranges
Viking wall oven No ignition
There is a transformer located on the oven that generates voltage to the ignititors. You have a bad transformer or a bad connection.
Dec 21, 2007 | Viking VGS0166 Stainless Steel Gas Single...
Viking VGIC485-6G Gas Kitchen Range Logo
2,905 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
