Question about Caere Lone Wolf TimeWolf Plus 3.0 Full Version for PC
Dll missing file corruption data missing cant open application help
  • 3rdhackimist May 11, 2010
    What particular of Program/Application?
  • 542 Answers
Search for the missing DLL file using search option in windows explorer. Copy the same to system32 folder and register the same using regsvr32 command.
e.g.: type regsvr32 XXXX.dll in Run command.
Revert back for more clarifications or assistance required.
Posted on Dec 15, 2009
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
Cant sign on to computer
    • 1 Download the missing comctl32.dll file. Locate a website that offers the comctl32.dll file. You can also use the link in the Resources section.
    • 2 Unzip the download file if it is a .zip-type file. Right-click on the file and choose "extract" to make the file available in a .dll format.
    • 3 Install the missing comctl32.dll file in the proper folder on the computer. If the operating system is 64-bit Windows, copy comctl32.dll to the "C:\Windows\SysWOW64" folder. If the operating system is 32-bit Windows, copy comctl32.dll to the "C:\Windows\System32" folder.
    • 4 Restart the computer by clicking on the "Start" button and selecting the "Restart Computer" option.
    • 5 Open the computer program that previously displayed the error message stating that the file comctl32.dll was missing. This will verify the program now works properly.
Nov 21, 2011 | Dell Latitude D 600/610
Notebook says that windows could not start because the following file is missing or corrupt <windows root>/system32/hal.dll.
Causes of the missing or corrupt hal.dll error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
To fix it:
1) Restart your PC, sometimes the hall.dll error could be an error itself and your PC should boot up fine.
2) Go into the BIOS by pressing the Delete key as the laptop boots. Then navigate to disk boot priority and make sure this is set to your main hard drive (the one that has Windows installed on it). Save and exit the BIOS. Sometimes if you have a USB flash drive/Pen drive or external hard drive it may automatically switch the boot priority to that.
If these two quick steps don't fix the problem then head over to here and continue reading up about repairing the boot.ini file.
Mar 10, 2011 | NEC PKM35-4A33 Buzzer (802870018009A) PC...
Acer Aspire One Netbook D260A.Windows XP not booting. Message Reads Windows could not start because the following file is missing or corrupt. Windows Root System 32 Hal dll No recovery disc or USB...
Sometimes you can get the needed .dll file online, and manually place it on that drive, of course in the correct directory.To do this, you need a functioning computer and you hook up the hard drive with the problem VIA USB. You can get USB Hard drive adapters from most retailers.
You may want to extract all data before you do anything, just in case. Have you been doing backups????
Usually, you reinstall the OS to resolve this issue, but without disks, not so easy to do.
Feb 03, 2011 | Computers & Internet
Hi i keep getting error messages containing d3d9.dll and d3d10.dll
http://www.fix-all-dll-errors.com/d3d9.dll/
http://www.fix-all-dll-errors.com/d3d10.dll/
Your faulty d3d9.dll & d3d10.dll can be repaired here...so just go to the link given above.
This will register the dll files on your system.
Jan 03, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hal.dll file missing or corrupted
Follow the steps given in the link below to troubleshoot the hal.dll missing issue:
http://support.microsoft.com/kb/945380
Aug 26, 2009 | Microsoft Windows XP Home Edition with...
Sir i have downloaded a game from net i installed it and tried to open but it gives a message "this application was faiiled to start because mss32.dll file is missing" plse help me to start the game
Mss32.dll Error is a common Windows error message. Mss32.dll Error is usually caused by a missing system files, wrong system settings or a corrupted registry file. Use CTRL+ALT+DEL to get the task manager, if there is anything listed with [Not Responding] end task it. Next, run a registry scan to check for registry errors & other system problems. 96% of the time this will fix the cause of the error
It is best to clean your registry in order to optimize system performance & Fix the cause of many Windows Errors.
Apr 14, 2009 | Computers & Internet
Windows system 32 hal.dll error after restoring e-machine
There's actually a number of reasons why these annoying little DLL errors happen, but the most common, is caused when new programs are installed over all old ones and the old ones are not completely uninstalled 100%, causing registry pile ups and of course, getting a .DLL error messages.
Another reason, is damage that's been done by malware/spyware/adware programs, attaching themselves to your PC and wrecking havoc, deleting crucial DLL files from your PC.
The hal.dll file is created during install from 5 other dlls. HAL is the Hardware Abstraction Layer and it's the interface between the system drivers and the actual hardware.
Copying hal.dll will not resolve the problem.
A lot of times the file will be reported missing due to corruption of the boot sector or of the file system
Causes of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll file or a hal.dll file that has been deleted or moved from its intended location.
Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged HDD.
Suggested remodies-
1. Restart the PC. The hal.dll error could be a fluke.
2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
6. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
7. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
8. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Important: If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
9. Replace the hard drive. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
10. Perform a new installation of Windows XP after installing the new hard drive.
I have not tried it - but HERE is a free program purporting to fix the error.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Apr 10, 2009 | E-Machines eMachines Desktop PC
Missing rundll file
Two ways out :
1.) Run a disc defrag on all the drives.
2.) Re-register DLL files : use this link www.techimo.com/forum/applications-operating-systems/158202-how-re-register-dll-files.html - 58k
Mar 19, 2009 | Acer Computers & Internet
HElp Plaese I Cant Autorun From Any CD Or Dvd Help .........System Files I Think Are Corrupted
The best thing to do is backup and reinstall vista because you might have a worm if you do`nt have a anti virus program download one at www.avast.com
:)craig
Jan 08, 2008 | ASUS (90N951W1000) DVD-RW Burner
Caere Lone Wolf TimeWolf Plus 3.0 Full Version for PC Logo
78 people viewed this question
Top Caere Computers & Internet Experts
David Payne
David Payne
Are you a Caere Computer and Internet Expert? Answer questions, earn points and help others
