Error reading general file for module 4 - Computers & Internet
  • 798 Answers
Hello there and welcome here :O)
In what program are you in when this happens ??
Have you try to reinstall it, you do it in this way :
Uninstall the program in Add and Remove programs in Control Panel, reboot the computer, install the program again, please update the program too
Have a nice Christmas
Let me know if I can help you more
Please rate my answer
Posted on Dec 12, 2009
SOURCE:
Tip
Beep Code Explained
Thanks to Transcend Technical Support for this great Brief of understanding beep codes that is found here
This is a long post and it may be truncated at the bottom. If so, use the link above to go to the Transcend web site where these are found
1.General POST (initial system boot) BEEP Codes
If you do not know the BIOS manufacturer, the following will be the general Beep codes:
• 1 Long and 1 Short Beep ?Bad Motherboard
• 1 Short Beep and nothing else happens ?Disk Drive/Video Related Problems
• 1 Long and 2 Short Beeps ?Bad Video Card
• 1 Continuous Beep or Non-stop short Beeps ?Bad Power Supply
• 3 Short Beeps - Bad Memory
2.American Megatrends Inc. (AMI) BEEP Codes
• 1 Beep - Memory refresh timer error.
Reseat the memory, or replace with known good modules.
• 2 Beeps - Parity Error
• 3 Beeps - Main memory read / write test error.
• 4 Beeps - Motherboard timer not operational
• 5 Beeps - Processor Errors
• 6 Beeps - Keyboard controller BAT test error.
• 7 Beeps - General exception error.
• 8 Beeps - Display memory error.
If the system video adapter is an add-in card, replace or reseat the video adapter. If the video adapter is an integrated part of the system board, the board may be faulty.
• 9 Beeps - ROM checksum error
• 10 Beeps - CMOS shutdown register read/write error
• 11 Beeps - Cache Memory Bad
Beeps 4-7, 9-11
Fatal error indicating a serious problem with the system. Consult your system manufacturer.
Before declaring the motherboard beyond all hope, eliminate the possibility of interference by a malfunctioning add-in card. Remove all expansion cards except the video adapter.
?If the beep codes are generated even when all other expansion cards are absent, the motherboard has a serious problem. Consult your system manufacturer.
?If the beep codes are not generated when all other expansion cards are absent, one of the add-in cards is causing the malfunction. Insert the cards back into the system one at a time until the problem happens again. This will reveal the malfunctioning add-in card.
3.Award Bios BEEP Codes
1 Long Beep: Memory problem
Explanation: There is a failure of some sort related to the system memory.
Diagnosis: The first bank of memory probably has a failure of some sort; this is usually just a physical problem such as an incorrectly inserted module, but may also mean a bad memory chip in a module. It is possible that there is a failure related to the motherboard or a system device as well.
• 1 Long, then 2 Short Beeps: Video error
Explanation: The BIOS is unable to access the video system in order to write any error messages to the screen.
Diagnosis: This is usually caused by a problem with the video card, or the memory on the video card. It can also be a motherboard issue.
• 1 Long, then 3 Short Beeps: Video error
• Continuous Beeping: Memory or video problem
Explanation: The system is producing constant beeping in no specific pattern, or a fast "ringing" sound.
Diagnosis: This is usually caused by a problem with the system memory, or possibly the video card. The memory is more likely--the system complains long and loud if it can't find any usable memory, as there is no way to even start the boot process when this is the case. The motherboard itself could also be the problem.
• Other Beep Codes
Explanation: You have encountered an Award BIOS beep code I do not have documented.
Diagnosis: Award says that any beep patterns other than "one long followed by two short" are likely problems with the system memory. However, of late they have started adding other beep codes to their systems as well.
4.Phoenix BEEP Codes
• 1-1-3
Explanation: Your computer can't read the configuration information stored in the CMOS.
Diagnosis: Replace the motherboard.
• 1-1-4
Explanation: Your BIOS needs to be replaced.
Diagnosis: Got to your motherboard manufacturers web site and download the new Bios.
• 1-2-1
Explanation: You have a bad timer chip on the motherboard.
• 1-2-2 or 1-2-3 or 1-3-1 or 1-3-3 or 1-3-4 or 1-4-1
Explanation: Motherboards is bad.
• 1-4-2
Explanation: Some of your memory is bad.
Diagnosis: Go to Basic Trouble Shooting
• 1-3-1
• 2-_-_ Any combination of beeps after two
Explanation: Some of your memory might be bad.
• 3-1-_
Explanation: One of the chips on your motherboard is broken.
• 3-2-4
Explanation: Keyboard controller failure.
Diagnosis:
• 3-3-4
Explanation: Your computer can't find the video card.
Diagnosis: Is it there? If so, try swapping it with another one and see if it works.
• 3-4-_
Explanation: Your video card isn't working.
Diagnosis: Replace Video Card.
on Jan 20, 2009 | ASUS P5W DH Deluxe Motherboard
ASUS P4V800D-X AMI BIOS AMERICAN MEGATRENDS BEEP CODES
Hello here is some beep codes:
Beep CodeDescriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed
My guess is you have a ram/memory module failure.
Try to renew the ram module.
The asus homepage is here:
http://support.asus.com/Download.aspx?SLanguage=en&m=p4v800d-x&p=1&os=
Here you can download a manual.
Please unzip the file when downloaded.
Your mainboard is using following type of ram:
Dual Channel Memory Architecture
4 x 184-pin DIMM Sockets support max. 4GB
PC3200/PC2700/PC2100 non-ECC DDR SDRAM memory
These module does not exist bigger than 1GB.
Oct 15, 2012 | ASUS Computers & Internet
What is error 4? and how to solve.balance is stuckedup
What does particular error code mean "General failure". Particularly for "General failure", the SFTP server should provide you more details, that you will see next to "Error message from server". Unfortunately, SFTP server shipped with OpenSSH (or Sun SSH) does not. That is, why you see there just "Failure" (very useful).
Some situations when OpenSSH (Sun SSH) server issues this useless error message:
a. Renaming file to name of already existing file.
b. Creating directory that already exists.
c. Moving remote file to different filesystem (HDD).
d. Uploading file to full filesystem (HDD).
e. Exceeding user disk quota.
thank you
Aug 02, 2011 | Computers & Internet
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Cannot open/save file
What type of file. Sounds like it's not a text or editable file.
Dec 28, 2009 | Computers & Internet
Problem Event Name: APPCRASH Application Name: iexplore.exe
I think it is a usual problems, u can try to delete some bad application or spam or anything from : internet explorer - select tools - then internet option - in tab general, choose delete and then checklist all components there - and then OK
if it is doesn't works, you just have to enabled/uninstall your internet explore through program files or registry
hope works,
May 30, 2009 | Microsoft Internet Explorer 7
Memory write/read error on start up
Do not post your service tag on any forum, it is private data and needs to be protected (some turkey tried to get some stuff from Dell on a friend of mine's account using her tag she had posted)
If the system will post and boot, try flashing the BIOS to the current version. Then try each RAM module one at a time. Generally, only one module will fail at a time. SO take one out, boot to BIOS (SO it recognizes the RAM quantity change) then see if the system boots without error. If it does, then the module removed is likely bad. If the error still occurs, try the steps above with the other module. If errors occur with only 1 module, replace that one.
If errors occur with either module, you may have a motherboard issue. Or, very unlikely, 2 bad memory modules
Mar 23, 2009 | Dell Inspiron 1525 Laptop Midnight Blue
General disk error reading when i insert a disk
Look at the floppy disk using Windows Explorer. You should see something to the effect of menu1, menu2, menu3 menu4 and one or two files with a file extension of something like .mhv or .phv . Inside the menu folders, you will find the .shv files.
Just writing the .vip or .hus to the floppy will not work.
Keep me posted and I'll try to come up with something more.
Oct 01, 2008 | Husqvarna Viking 1
Computers & Internet Logo
202 people viewed this question
Alun Cox
k24674
