Question about TurboChef TORNADO Electric Oven
Turbochef toaster oven cc temp on warm up only 265 deg ir 465
When switching on the speed oven it goes into warm up mode , it displays cc temp and ir temp for 5 minutes it rises to approx 465 deg on ir probe but cc probe displays only 275 deg , . so when you select toaster button it will cook for 20 seconds , but it doesnt toaster that well , i have started fixing these ovens , but they are little more complicated than the commercial ovens i have fixed before, so i need some expert advice, on why the cc temp does not rise high enough ,
    Scholar:
  • 75 Answers
If your a commerical oven tech then just call 1-800-90turbo are you getting an error code i would probably check the convection circuit first starting with the blower motor and checking if the Windings are ok
Posted on Jan 28, 2010
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Turbochef tornado toaster wont get to menu, just warming up
The most common issue with this is a bad IR element. When the oven is cold remove the metal rack. you will see the IR element on the bottom. turn the oven on. wait 1 min. open the door and see if the bottom element is warm at all. If the bottom element is still cold then you have a bad element.
Feb 13, 2013 | TurboChef TORNADO Electric Oven
Fault code Close door (S) keeps coming and oven won't start
The oven is telling you that the secondary switch is not working. Either the switch is broken or the door or switches are out of alignment. the switches cost about 4 dollars. Not an expensive repair by any means.
Sep 09, 2012 | TurboChef TORNADO Electric Oven
In edit mode my oven seems to warm up past the preset temps and trip the overheat relay, also in cool down mode when i open the door it shows the IR steadily going higher to 1000F and seems to stay in cool...
Bad SSR relay, te relay is shorted it keeps feeding the power to the it element . Or else bad IO board. You should know how to diagnose it though. Otherwise don't touch it
Feb 18, 2012 | TurboChef TORNADO Electric Oven
I get an f8 error code. Oven not heating up
Reset the high limit thermostat switch on back side of oven. If that doesn't helped then either your IR element is out or cc heater is bad
Feb 08, 2011 | TurboChef TORNADO Electric Oven
I am working on a Maytag Oven Model #MER5555QAW. You turn the oven to 350 deg. It goes immediately to 350 but then the temp goes off. It will not maintain the desired temp. Is this the sensor or the...
So are you saying that the oven does not start at all?The 350 just appears on the display and then pressing enter it disappears?Does it warm at all?If it warms,it is most likely the thermocouple or ASM,both are the same,just varies between makers.If it does not heat at all,it sounds like somehow the temperature setting got switched from F to C somehow,which can happen completely not done by you.Let me know which situation you have and I'll figure it out.Greg
Nov 24, 2010 | Ovens
My oven is on warming mode from last six hours. Please adivse
First, check the back of the oven. See if the lil red button can be pressed in. Then check the IR Element, usually you can see the wires burned or damaged where it enters the oven by the snap rings. This was a design flaw from the manufacturer of the element of which turbochef has taken care of.
COMPONENTS
IR Element
The IR element - a dual coil type heater - is located
in the bottom of the oven cavity. The first coil is the
heating coil. The second is the IR thermocouple
wire. The heating coil outputs 3000 watts at 208
VAC. The heating coil's resistance is 14.4 ohms at
room temperature.
The thermocouple coil is a Type K thermocouple
with a resistance of approximately 20 ohms at the
splices located approximately 6 inches from the
heater and 40 ohms measured at the extension wires
at the I/O control board.
The IR element is controlled via the K5 solid state
relay and the IR thermocouple via the I/O control
board.
Its typically an easy quick fix.
Nov 02, 2010 | TurboChef TORNADO Electric Oven
TurboChef TORNADO Electric Oven Logo
765 people viewed this question
Top TurboChef Ovens Experts
Steve Allison
Steve Allison
Dennis Boxerman
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
