Can i run turbo c in my dell studio 15 there are eror for windows 7 ''64 bit''
  • 622 Answers
Try running it in compatibility mode... right click on the exe and select properties and search for compatibility... if setting to run as xp does nt work then you might need to get an upgraded version or another software that can do what you need...
Posted on Dec 12, 2009
Disc goes in ejects after a second
Any disk? Do you have a Laser cleaner disk?
Dec 04, 2012 | Dell Studio 15 Laptop
My mice s not workng in dell studio 15 in windows vista wt to do?
run diagnostics Fn + Power and see if the touchpad works in diags
if ti doesn't then replace the palmrest
if it does, try a system restore to before the issue occurred
Sep 10, 2010 | Dell Studio 15 Laptop
HOW TO RUN TURBO C IN 64 BIT WINDOWS 7
Turbo C/C++
64 Bit operating systems like Windows Xp64, Windows Vista64, and Window 7 will no longer run 16 bit applications and this includes Turbo C 2.01/Turbo C++ 3.0/3.1 or the programs they produce.
Turbo C 2.0 was first released in 1989, Turbo C++ 3.1 in 1991 making these programs nearly two decades old. They are just too old to run on modern PCs.
Upgrade To Modern Compiler
Note that Turbo C/C++ is very very very very old and produces 16 bit programs which no long run on many modern computers. So the best advice is to upgrade to a new compiler. There are many free compilers out there that you can use.
Free Compilers:
  • Microsoft Express 2008 -- Great compiler and comes with a nice IDE (Visual Studio)
  • MinGW -- Command line compiler but there are many IDEs that use it such as Code::Blocks, Eclipse, Dev-C++
  • Borland C++ 5.5 -- Will compile Turbo C++ programs (including graphics.h) but produces 32bit code (slightly better than Turbo C) Only includes command line tools.
  • DigitalMars -- Its still old but at least it produces 32bit programs (better than Turbo C). You might stumble across D++ which is a very powerful language derivative of C++.
  • OpenWacom -- Again, nearly as old as Turbo C, but it produces more modern 32bit applications! (this project is still active too).
If you are just working with C there is:
  • Pelles -- and excellent modern C compiler and IDE. Pelles also has the new TR1 libraries available so you can use regex and other new features. As well as support for many older libraries.
  • LCC-Win32 -- Used as the basis for many of the research compilers.
  • Tiny C -- is said to produce very fast programs.
All of the above are Free and all excellent replacements for Turbo C which is so old it will not even run on your computer.
Regards.
May 24, 2010 | Microsoft Windows Vista Ultimate Edition
Dell Studio 15 Laptop...dvd drive
try booting comp using the windows disc -if it still makes clicking noise and spits the disc out update the firmware. if it still acts the same way, replace it.
Mar 04, 2010 | Dell Studio 15 Laptop
Why turbo c does not work in windows 7 64 bit
You're a programmer you should know this. Turbo C is a 16 bit application. 64 bit operating systems cannot run 16 bit applications. You need to get the 32 bit version of Turbo C or upgrade to a newer compiler.
http://www.fileguru.com/apps/turbo_c_for_windows_7_32_bit
Jan 22, 2010 | Dell Inspiron 6400 Notebook
Is it possible to install windows 2003 server and windows xp on studio 15 laptops?
yes, how ever you must format them install windows 2003 server first on its own partion on the hard drive, and then install windows xp in its own hard drive.
how ever,, each OS has its own operating system, and depending on what your planning to actually do with them may determine how well thier gonan work. Example if your just gonna use them for class room exercises so your students can learn and manage a lan website on their computers then it might be ok. if you wanna host actually websites, then your gonna run into a lot of issues especially with space.
your avg dell studio specs
Processor
  • Processor Intel Pentium Dual Core T4300 / 2.1 GHz
  • Multi-Core processor technology Dual-Core
  • 64-bit processor Yes
  • Data bus speed 800.0 MHz
  • Chipset type Mobile Intel PM965 Express
Memory
  • Type L2 cache
  • Cache size 3.0 MB
RAM
  • Installed Size 3.0 GB / 4.0 GB (max)
  • Technology DDR2 SDRAM - 400.0 MHz
these are all well above what you would need to run the OS.
please mark this as fixya if it was helpful
Jan 09, 2010 | Dell Studio 15 Laptop
My dell studio 1555 webcam stopped working and it says ''close other video streaming devices to start video''
1. disable all streaming files and apps first.
2. run system restore, restore the point when webcam was working fine. if fails.
3. uninstall / reinstall webcam driver. if fails.
4.
Oct 10, 2009 | Dell Studio 15 Laptop
ITunes ''not responding'' using VISTA 64-bit
are you running itunes 64 bit? that would be your solution there. download the 64 bit version and it'll solve all your problems.
Aug 03, 2009 | Microsoft Windows Vista Home Premium...
How can i get Network drivers for windows 2003 server on Dell studio 15 laptop
Hello
first you need to share it from the server example d:\data
then you need make a connection to your srever from your dell.
example
If the servername is "BOSS" then you should click start run and write \\boss on your dell computer.
If the server and dell is on the same net it gonna popup a window.
right click on the "DATA" catalogue and "map network drive" use a letter example Z: and mark the square reconnect when windows start or something like that. then you gonna find this on your "My computer"
Jul 10, 2009 | Dell Studio 1535 Notebook
M-audio not connected in windows vista
have you vista supported driver ifyou are not it is the driver only 32 bit windows not for 64 bit
Jun 29, 2009 | M-Audio Fast Track Pro External Sound...
Computers & Internet Logo
David Payne
David Payne
