Question about InFocus LP70+ Multimedia Projector
I HAVE AN INFOCUS SCREENPLAY 5000 PROJECTOR THAT DISPLAYS THE MESSAGE "ONE OF YOUR FANS ISNT WORKING SO SHUT DOWN WILL OCCUR SHORTLY"... PLEASE TELL ME WHAT I CAN DO TO FIX THIS ISSUE. THANK YOU IN ADVANCE.
  • 2,237 Answers
There are 2 fan assemblies in this model. a double fan for the lamp, and a single fan for the dmd chip. check for obstructions through the vents (pieces of plastic or paper will stop the fan). if nothing is in there, you could buy the parts from an infocus service center and replace them yourself or send it to them to fix. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Posted on Dec 14, 2009
Hello I have the infocus screenplay 5000 projector & after reading all the posts here decided I dont have a similar problem to anyone else. My bulb life expiration came up months ago but the unit works...
working with expired lamp can cause the overheat, and the power supply will be damadged, you need to replace the chemical caps at secondary parts as shown in the picture below:
Feb 11, 2014 | InFocus ScreenPlay 5000 Multimedia...
Infocus 5000 won't recognize my computer
How about a little more information?
Does the projector turn on?
has it ever worked?
What type of interface (VGA, DVI, HDMI, RCA)
What type of computer (notebook or desktop)
That being said, double check your cable connections and make sure you tell your computer to look for the projector (Dell laptops used to use FN+F8 to switch from laptop to projector). Windows 7 has a menu choice "Connect to Projector". Mac computers - check system preferences and make sure the projector is ON before you plug it into the Mac.
Nov 25, 2012 | InFocus ScreenPlay 5000 Multimedia...
The lamp on my Infocus Screenplay 7210 shuts down
the projector thinks it is overheating. you may need to replace the temp sensor. it located near the lamp plug. also make sure the fans are both moving.
Jan 24, 2010 | InFocus ScreenPlay 7210 Multimedia...
Projector shows briefly and cutsl off
are you sure it's the fan? if the lamp cuts out and the fans still run, the problem is the colorwheel. if you are sure the fan is not moving, it will need replacing, but there is no fan sensor that would shut the projector down if the fan does not spin. there is, however, a temperature sensor that'll shut it down if it gets too hot. wheather it's the fan or the colorwheel, clean the dust out of the projector with canned air to help prevent overheating. then get the parts from an infocus service center and replace them yourself, or send it in for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 28, 2009 | InFocus ScreenPlay 4805 Multimedia...
New lamp, no power!
if there are no leds lit, i'm surprised that it powers up. but if there is no light when the fans are running, it may be the ballast that needs replacing.
Oct 14, 2009 | InFocus ScreenPlay 5000 Multimedia...
Can't start infocus sp7200 after changing lamp.
The end of lamp timer has reached it's limit and won't let the new lamp strike. What you need to do is Reset the end of life timer. To do this, with the projector switched off press and hold both the up and down Brightness buttons on the projector. while holding them in turn on the projector. Continue holding the buttons in for 10 to 15 seconds This will reset the end of life timer in the projector.
Cheers
Sep 25, 2009 | InFocus ScreenPlay 7200 Multimedia...
InFocus litePro won't turn on.
With a bit of luck a fuse may have blown though almost certainly the lamp has gone. Never **** the projector when the lamp is on.
Aug 28, 2009 | InFocus ScreenPlay 5700 Multimedia...
Light shutting down after 15 mins
it's overheating. clean it out and try again.
Apr 02, 2007 | InFocus ScreenPlay 7200 Multimedia...
InFocus LP70+ Multimedia Projector Logo
156 people viewed this question
Top InFocus Office Equipment & Supplies Experts
neOen
Level 1 Expert
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
