Question about Sony VAIO VGC-V517G PC Desktop
Computer don`t turn on / Enginners in service center said that motherboard don`t work
Does your computer display anything?
Posted on Jan 02, 2010
  • 181 Answers
What do you want to know you have already answered the question.
Posted on Dec 12, 2009
My laptop model is hp compaq nx6120..Its showing the error as non-system disk or disk error replace and strike any key when ready...hw to recover this error?and also cant able to view the bios settings...
You may have a defective Motherboard (BIOS or CMOS chip to be specific). Normally, a non-system disk error can be attributed to a failing hard drive. But since you mentioned that you cannot access the system configuration, that means your BIOS is not able to see your bootable device anymore. You may need to have your computer serviced which means a motherboard replacement.
But before you send your computer to a service center, try to discharge flea power first. You may be surprised how many issues it can resolve. You can do this by removing the battery and the AC adapter of your computer. After doing this, hold the power button down for at least 5 seconds. Reconnect the components, and then try to turn your computer on. Hopefully this works so that you don't need to spend as much. The cost of a motherboard replacement would be more like replacing your whole system. Good Luck!!!
Jul 01, 2011 | Computers & Internet
Bios password for motion computer le1600
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: biospasswordrecovery. com
May 17, 2011 | Motion Computing AP42332 LE1600 Notebook
Forgot bios password
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Apr 26, 2011 | Gateway MT6451 Notebook
Screen flickers then reflects, after a few minutes it goes blank.
your display connector is loss or dameged then you check to authorised service enginners
Jan 27, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Segate portable hard drive 500 gb not able access
is the computer see ing it if not ,unplug run computer then turn off re plug in and computer should see it with its plug and play system
Jul 06, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
My PS/2 of keyboard and mouse are not working
The soldering of the PS/2 must have gone loose. Take your cpu to near by computer service center and fix it.
All computer service center people will fix it. So its not going to be a big problem. Or if the product is under warranty, take it to where you have bought it and fix it.
Jun 30, 2010 | Intel Motherboard
I tried yesterday 6-7 times to turn it on
Hard to deduce but it could be a issue with the BIOS/CMOS chip too. Is the Vaio still under warranty ? If no then unfortunately, would need to have it checked again at the service center and follow those guys :(.
If its showing past time than that indicates (1) the CMOS battery is dead (2) Motherboard circuitry has issues.
Feb 10, 2010 | Sony Computers & Internet
Computer simply don´t open, mother board doesn´t too
TRY ANOTHER RAM IF THIS DOES NOT WORKS
TRY RESETTING THE BIOS CONFIGURATION FROM THE JUMPER ON THE MOTHERBOARD
OR ELSE THE MOTHERBOARD NEEDS A REPAIR IF IT FALLS UNDER WARRANTY PERIOD
TAKE IT TO THE SERVICE CENTER OR ELSE BUYING A NEW ONE IS THE BETTER OPTION
Jul 08, 2009 | Computers & Internet
Can't switch on monitor screen
You must go into the BIOS of you computer and turn off the sleep mode and also in windows. Disconnect the monitor and power it on without hooking it up to the computer. If the monitor turn on and is working , then hook it up to the computer and try with with the sleep controls off to see if it works correctly.If this works you must check the owners manuals of the motherboard and monitor for the correct operation of the sleep mode functions.Then reinstall the sleep mode operation and see if everything works correctly. If the monitor fails to work. Try the monitor on another computer and see if it will function. If all this fails to get the monitor working , then you will need to have the monitor tested in a service center to find the problem and have it repaired. You should also check your computer on another monitor just to maker sure you don not have a problem with the computer too. Hope this helps you with your problem.
May 12, 2009 | Mag Innovision LT776s 17" LCD Monitor
Have sound no picture need repair
Hello bumit,
you need to bring your unit, to your nearest shop/service center..
it was the flyback transformer need to be replace...
try to contact service techiacian/enginners of your area.
thanks
regards
Clyde
Dec 01, 2008 | Philips Televison & Video
Sony VAIO VGC-V517G PC Desktop Logo
52 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
