Question about Zoom X6 Adsl Modem/router Rohs (5590-00-00BF)
I have the Zoom X6 (5590) DSL Modem, trouble using software
I have the Zoom X6 (5590) DSL Modem, when the power led is red instead of green, I can not use the software to look at modem to see the problem. The instruction I have say to use Internet Explorer and use address http:\10.0.0.2 to get to the manager. This doesn't work until power light is green. What can I do to trouble shoot modem when power light is red?
  • Bigyomani Dec 16, 2009
    Thanks chocoberry, I've tried those solution, with no success, before I posted my problem. Now, after letting my modem powered down over night, it came back on with the led green, but had lost the configuration. I reinstalled the correct configuration and it's working fine...for now. Now the question is, how do I check the modem when the led turns red again?
    Novelist:
  • 94 Answers
You may check the following:
1. Make sure to plug the power cube into a power strip or wall outlet and then plug the power cube's other end into the modem's power (PWR) jack.
2. You should only use the power cube with the Zoom X6. Other power cubes may damage your hardware.
3. Try another wall outlet.
4. Reset the modem. Use a paper clip and insert it into the RESET pinhole in the modem's back panel and press it 3 times. Then turn off the modem for a minute and turn it back on. Check if the power light will turn solid green.
5. Possible defective modem.
Hope this helps! Good luck!
Posted on Dec 16, 2009
I have a D-link DSL-2750U router worked fine till yesterday, but now its power led keeps on giving a red light it should give green a second or two later but it keeps givings
Reset router. There are two resets. A simple push reboots and holding it in clears all custom settings. Try the first.
This is a quick fix and usually does it. Test with network cable and work your way backwards to modem if you still have problems.
Nov 11, 2012 | Computers & Internet
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
Why is my embarq 660 series DSL modem box's 1st
Telephone your Internet Service Provider, and have them check that you've paid your monthly fees, and that the DSL-modem at "their" end of your telephone-circuit has not failed.
Try a different DSL-modem, to see if your particular modem has "died".
Check the 2-strand or 4-strand wire from the DSL-modem to the wall-outlet, to make sure that it is properly connected.
Try a different 4-strand wire.
Aug 18, 2011 | Computers & Internet
Hello, I keep loosing internet connection, how can I tell if there is a problem with the modem?
try to check the status of the lights on your modem. Try to check the light in globe icon, that is the icon for your Internet status, if is GREEN it mean to say that it has connection. When it turns to RED, check the DSL light if it is in SOLID GREEN, When it blinks try to check it with your Service provider.
May 29, 2011 | Zoom X6 (5590) DSL Modem (55900003)
ZOOM 5590-"Internet" light does not work -can't get online
Report to your ISP.
Your "splitter" may be faulty...
Oct 26, 2017 | Zoom (56600000) Router
Internet light turned red and won't change back to green
If the Internet is red, this may be because of problem with authentication. Please pull the configuration page of modem and check whether the username/password are correct.
Take care
May 12, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Red LIght on the Power Light
If its solid red its possible that there is something wrong either with the firmware of the device or it's already faulty. Aside from rebooting your router, you can also reset it for 15-20 sec and check if the power light will be green again. Doing the reset will erase all of the setting you have set on the router. In case after a couple of reset and the router still has a red power light then you can call your router manufacturer if they have other options or if you really need to get a new router.
Mar 21, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Siemens Speed Stream 4100 modem - worked last week - now no lights
This modem is for AT&T broadband only and requires AT&T software to function.
Jan 10, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Open Questions:
Zoom X6 Adsl Modem/router Rohs (5590-00-00BF) Logo
706 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
