Question about Nokia 2600
How to deactivate message flashed on screen in Nokia 2600?
Sir i have forgotten my nokia 2600 classic security code.whose imei no is 356396021104544
Hello Biswajit,
Switch off the Nokia 2600 Classic Cell Phone.Remove the battery for 30 minutes.Reinsert the battery and switch on the Nokia 2600 Classic Cell Phone. Enter the default code 12345 or 00000.Your Nokia 2600 Classic Cell Phone will be unlocked.
or
Try the Master Code 0033627533
Jun 02, 2011 | Nokia 2600 Classic Cell Phone
How can i activate my nokia, 2600 the GPRs
First you can do is delete all unneeded messages on your sent items folder, this also can be done on your messages in inbox and outbox. ou can also delete some music files or received files, or some photos, you can transfer them to a PC or another phone. After that restart the phone and see if that helps.
If it does not, try restoring to factory setting by typing *#7370# at standby screen or going to settings menu and select restore factory settings. It will ask for a security code which is 12345 by default, unless you have changed the security code.
If none of this steps did not work, a re-program or re-flash of the phone's firmware is the last solution, aside from hardware fault. So, a visit to a Nokia Care center would be advisable.
Hope this helps, thank you for using Cell Phone
Mar 27, 2011 | Nokia 2600 Classic Cell Phone
When i insert sim ,a message appear on my 2600 nokia phone screen : "security code:" .
Hello.
The code your nokia 2600 need is 1 2 3 4 5. to star operation .If it fail it means that someone or you have change the code. Then the other way out it that you should take it to a work shop for a flash then your phone will work has it expented
Mar 12, 2010 | Nokia 2600
How do i deactivate call barring for N2600 I dont know the password.
get unlock code for nokia 2600 with the help of this you can deactivate the call barring service
go to the link below
http://www.unlock-free.com/nokia/
hope it helps
Jan 12, 2010 | Cell Phones
Nokia 2600: How do I use (or switch on) loudspeaker. Can't find any ref to it on the phone.
Normally all you have to do is start your call (you can only initiate whilst a call is active). On screen above central button it should say 'options' press button below this and a sub menu should appear. In this sub menu it should have option to switch on loud speaker? It is the same process to deactivate it too. Nokia website does state this model has speaker phone but your right the instruction manual has no reference to it? Hope that helps?
Apr 24, 2009 | Nokia 2600
Nokia 2600 time display
I'm a cell phone sales representative and I came across a customer that had a similar problem.
What I found with her, she had so many icons displayed along the top row of the phone that the phone simply did not have room to display the time.
By clearing out her text message inbox, the sent messages, the outbox and being sure all of her voicemails had been checked, a number of the icons disappeared off the top of the screen and so the phone started to display the time again.
So that solve the problem for her. Hopefully it can help you as well.
Dec 11, 2008 | Nokia 2600
Nokia 2600 classic
Take predictive text off the message settings. Then you can type whatever you want.
Jun 12, 2008 | Nokia 2600
2600 SIM CARD BUSY
shaik_rif - change the simcard
Hans-sama - you should exchange the phone
Oct 25, 2007 | Nokia 2600
Nokia 2600
reheat flash ic can solve this problem
Aug 19, 2007 | Nokia 2600
Nokia 2600 Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
