I'm planning on installing windows 7 on my samsung p28,i kinow that aero wont work,but will i have any other issues/problems with installing required software???
  • 181 Answers
Do put on unless you need to. i have seen windows 7 on a laptop and apart from fast startup i cant see any real diffrence yet. have to admit it was a xmas present and i was setting it up but then i still could not see anything diffrent apart from no aero or dream scene.
Posted on Dec 12, 2009
Will Windows 7 install on my HP Pavilion?
You should run windows upgrade advisor as I don't think your specs meet the requirements
Mar 18, 2014 | HP Pavilion a600n PC Desktop
Tip
Areo will not start on a clean installation of Windows 7
I just resolved this issue on a new system. The user had been running the system about 5 days and the Aero would always drop out to Windows Basic mode as soon as the system booted to the desktop.
The cause turned out to be the Windows Experience Index had not been run.
Windows 7 requires a minimum Windows Experience Index before the Aero Experience to function.
If Aero will still not run after the Windows Experience Index has been run, tun the Aero troubleshooter and reboot after the troubleshooter finishes to resolve the problem.
on Mar 19, 2010 | Computers & Internet
Tip
How to get Aero on a Computer without Vista, or on an unsupported video card.
We all like Vista's Aero, even after 7 came out. But for most of us, we just don't want to stop using XP. Or we upgraded, and our computer doesn't support it. So, i am here to recommend a few programs that will give you an Aero Effect.
The first - Window FX - This will give you all the Aero Fade in and Out, and other effects that come with vista. Some versions support Transparency The download is here: http://www.stardock.com/products/windowfx/
The second - TrueTransparency - http://www.crystalxp.net/galerie/en.id.5139-truetransparency-lefreut-explorer-tools.htm This will give you Aero effects, and allows you to have different skins for it.
Others: Visual Tooltip which gives you a Tooltip when you put your mouse on the task bar, which comes with Window FX. http://www.chrisnsoft.com/visual-tooltip/
AeroShake - AeroShake is a Windows 7 Emulator. It allows you to shake a window, to hide all the others. This comes with TrueTransparency, so if you plan on using TrueTransparency, you don't need to install it. http://aero-shake.en.softonic.com/
AeroSnap - AeroSnap is also a Windows 7 Emulator. It allows you to drag a window to the top, or sides of the screen, and it will either maximize, or pull to either side of the window. http://www.mydigitallife.info/2008/11/29/aerosnap-free-download-to-enable-windows-7-aero-snap-features-in-xp-and-vista/
All together, these should satisfy, for now, our cravings for Aero, at least until our next computer...
on Jan 08, 2010 | Computers & Internet
I have sis 661fx Motherboard with intel 3.06 GHz processor with 1gb Ram.I have installed Win 7 last month.The Aero feature is not working on my system.i tried to update the drivers but wen i troubleshoot...
Did you run the Windows 7 upgrade advisor before you installed Win 7. You may find that windows 7 doesn't allow the use of your graphics hardware. With the issue of Win 7, Microsoft decided that they would only allow the use of hardware that had been tested by themselves. To enforce this all drivers for Win 7 onwards require "Signed Drivers" to operate properly. You may need to buy a Win 7 ready graphics card to continue with a stable computer.
Feb 19, 2013 | Computers & Internet
How can i used aero in windows 7 ultimate
Basically if your laptop''s Video Card or GPU has already the minimum requirements to run windows aero it will be automatically be turned on upon installation of Windows 7.
However in some cases windows aero will not be enabled if your driver did not match your Video Card so remember to install the right driver for your Video Card.
A quick way to know that your laptop actually can run windows aero is by running the Windows Experience Index. Right click on computer then click properties. The score (both base score and subscore for graphics component) should be equal or higher than 3.0 for Aero to work.
Jun 25, 2011 | Clevo MOBINOTE M540SS LAPTOP LCD SCREEN...
Dont get aero
To display Aero effects such as transparency in Windows 7/Vista, follow these steps:
1. Click on Start menu.
2. Type the following text into the Start Search box: Aero
3. Click on a search result listing under Control Panel group that named as the following:
Find and fix problems with transparency and other visual effects.
Trick: If you don't see "Find and fix problems with transparency and other visual effects" in the search results, click on Control Panel to see all Aero related items in Control Panel.
4. An "Aero - Troubleshoot computer problems" wizard dialog will appear. Click on Next button.
5. The troubleshooting wizard will try to detect any problem by running a series of checks against various components required to make Aero works and running, such as video memory, Desktop Windows Manager (DWM) service, color depth, theme, power settings and etc. At the end of the analysis, the wizard will attempt to fix the issues related to Aero service and restart the Aero feature.
Tip: If there is still items that are marked with red cross which indicates is the problems that prevent Aero from working properly, fix the issues and then rerun the "Find and fix problems with transparency and other visual effects" troubleshooting wizard again.
Tip: To create a shortcut to 'Find and fix problems with transparency and other visual effects', right click on it on search results, and then click on Open file location. On the "All Tasks" window opened, right click on Find and fix problems with transparency and other visual effects again, and select Create Shortcut to place the shortcut on desktop.
Hope this help. Goodluck!
Mar 28, 2011 | Biostar P4M890-M7 Motherboard
I have a Samsung SyncMaster 173s. Can I use it with Window 7? Is it compatible with window 7? Thanks for your help.
I've installed Windows 7 on some pieces of junk and found it to work great. The downside to installing it on older or under-performing machines is that you probably will not get all the bells and whistles that 7 comes with like the Aero features and probably will just hold you to the windows classic theme. But functional features like pin-to-tab will work.
Mar 28, 2011 | Samsung Computers & Internet
Please i want to enable aero in windows 7 my direct x is 11 and 64mb graphics
Hi waquashashmi,
A way to know if your Windows 7 system supports Aero or not is to look at Windows Experience Index score. The score (both base score and subscore for graphics component) should be equal or higher than 3.0 for Aero to work. To view your Windows Experience Index, go to Control Panel -> System and Security -> System, then click on "Windows Experience Index".
To display Aero effects such as transparency in Windows 7, follow these steps:
  1. Make sure that Windows Experience Index has been calculated and computed.
  2. Click on Start menu.
  3. Type the following text into the Start Search box: Aero
  4. Click on a search result listing under Control Panel group that named as the following: Find and fix problems with transparency and other visual effects
  5. An "Aero - Troubleshoot computer problems" wizard dialog will appear. Click on Next button. arun_zac_17.jpg
  6. The troubleshooting wizard will try to detect any problem by running a series of checks against various components required to make Aero works and running, such as video memory, Desktop Windows Manager (DWM) service, color depth, theme, power settings and etc. At the end of the analysis, the wizard will attempt to fix the issues related to Aero service and restart the Aero feature. arun_zac_18.jpg
If this information was helpful, please rate it.
Thank you for using Fixya,
Arun Zac
Dec 07, 2010 | Vga GeForce4 Ti4200 64MB DVIout AGP Card...
Helo i am using acer 4315 and i increased ram to 1 gb with window 7 ,is any problem using windows 7 in my machine?
windows 7 will work on your machine but because of your graphics card you wont be able to run the aero part of windows and 1gb of ram is the minimum requirement for windows 7 that wont leave you with much ram left over to run other programs unfornutatly
Nov 09, 2010 | Acer Aspire 4315 Notebook
P28 laptop blue screen it starts up with the windows logo then shuts down
hello
i have problem my laptop no work and i search laptop P28. i want buy model laptop P28. i need in changer block mainboard for loptop P28
If you can me help. please help me. i buy old laptop Samsung P28
hope you help me
Thank you
my e-mail: Live29@yandex.ru
Sep 24, 2009 | Samsung V25 XVC 2800 Notebook
Computers & Internet Logo
76 people viewed this question
Alun Cox
David Payne
David Payne
