Question about Samsung SGH-i900 Omnia Unlocked Cellular Phone
Says cannot connect to server
Says cannot connect to serve. I am in Zambia. My fone said memory was a problem so I did a hard reset. The next day I asked MTN Zambia to send me the settings for the internet, now when I log onto the net to try download Mxit, it tells me its trying to connect to Vodacom. How is that when I already have MTN settings onmy phone and am trying to connect to MTN....not Vodacom!!! There is no Vodacom here in Zambia.
Please help, What settings do i set on my phone as they say its not a server problem.
Help!!!!
I am using Samsung Wave II & da prevoius owner has email & facebook account ,now I cant login
Take it to fone server provider that u have and they can help u reset it or look in the fone s tools for the fone reset
Aug 05, 2014 | Computers & Internet
How do i get vodafone gprs settings on htc p3400i
Go to Start->Settings->Connections->Tasks->Add a new modem connection:
Enter a name for the connection:
ex. Vodafone
Select a modem:
Cellular Line(GPRS)
click next
Acess point name:
portalnmms
User name:
Password:
Domain:*
Go to Advanced->TCP/IP
select radio button "Use server-assigned IP address"
Go to Advanced->Servers
select radio buttion "Use server-assigned address"
Step 2
Start->Settings->Connections->Tasks->add proxy setting
Select "This network connects to the Internet"
Select "This network uses a proxy server to connect to the Internet"
Click "Advanced" button
Tap on HTTP
Server: 10.10.1.100 Port:9401
Username:
Password:
Domain:
Tap on WAP
Username:
Password:
Domain:
Step3:
Start->Settings->Connections->Advanced
In "Select which networks are automatically used"-> click the Select Networks
Programs that automatically connect to the Internet should connect using:
Select the Connection name which you configured in Step 1
Programs that automatically connect to a private network should connect using:
Reboot the mobile for the changes to take effect.
Mar 16, 2011 | HTC Touch P3450 Smartphone
N 97 Gps not working
hard reset your fone...before doing that though, sync all your contacts, msgs, pre-installed apps. Hard reset doesn't format mass memory so stuff in your mass mem will stay intact - maps, apps in mass memory, photos, videos etc. Hard reset is a good tool if you want to ease up the fone memory...you will need hard reset sometimes anyways because the n97 tends to freeze - its fone memory fills up somehow when you download apps even though u r installing them on mass memory.
to hard reset:
1. turn your fone off
2. press caps,delete, space and power button at the same time.
3. fone restarts and is reset.
Hard resetting somehow eases up the GPS signal. I did that and now it connects in seconds (maybe its got to do with fone memory being cleared up). I also read this in a blog somewhere.
Aug 12, 2009 | Nokia Cell Phones
My n73 phone starts with installation and says application not supported everytime.
just update ur fone firmware OR hard format ur n73... by following method:
(note : b4 u do any of the above solution remove the password of memory card and also take the backup of ur memory card through Nokia pc suite not by using cardreaders....)
hard format :
remove memory card
switch off the fone
now press call key(green) + 3 + * key
keep on pressing all three keys and switch on the fone ... dont release the keys untill the fone boots on....
the fone settings will be restored to its default... also all d security codes of fone will be retored to defaults....
now ur problem is solved .... put ur memory card back.... n if it still asks for memory card unlock password ... then jus format it .....through fone..... it wont ask again.....
regards
Bhumit
Feb 03, 2009 | Nokia N73 Cellular Phone
W230 cant connect to a pc
http://www.cellphone9.com/motorola-w230-file-transfer-problems-firmware-update/
follow the above line.... and probably you must have a memory card in the fone.... once you are done with downloading the driver  connect the fone and you would get the 'found new hardware baloon' select 'no not this time' and click next and browse to the driver which is downloaded, click next and finish the process...
once you remove and connect the fone you would get a prompt on the fone's display "connect phone as storage device" click yes to transfer data or click no or leave it alone for the fone to get charged...
hope this helps you..
use this alt link to download driver
http://direct.motorola.com/hellomoto/in/support/usb_drivers_pc_charging_drivers.asp
incase of any further clarifications  vishal at games.com....
Cheers, vishal...
Nov 12, 2008 | Motorola Mobility W230 Phone US with...
NOKIA N73 problem
try updating the fones firmware from nokia's website or else u can try *#7370# this the hard reset of the fone but dont forget to back up the data thats on ur fone like CONTACTS,THEMES THAT U INSTALLED ON FONE MEMORY,MESSAGES ETC by using PC suite thru cable.Hope this would solve ur problem
GOOD LUCK
Jun 11, 2008 | Nokia N73 Cellular Phone
Reset blackberry 8700
my blackberry 8700g on/off ligt red
Apr 16, 2008 | RIM BlackBerry 8700c Cellular Phone
Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
227 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
