Question about Philips TP3284C 32" TV
Power light blinks repeatedly on my Philips TP3284C
I'm not exactly sure what caused the TV to do this but, it will no longer turn on. You can hear the relay click, but the tube does not try to turn on. The power light just blinks continuously until unplugged. Any thoughts would be appreciated.
  • Sam Jan 23, 2008
    If you hold power button for 3 seconds it gives five blinks repeatedly. Actually if I press any other button (Chan/Vol), power light comes on (click) and goes back off (click). There is nothing damaged on the circuit board either. Could someone tell me how to check the HOT to see if it is damaged?
  • 54 Answers
Defective Horizontal output, or Flyback shorted. Need to Check up.
Posted on Apr 14, 2008
My tv will not come on but I hear a clicking sound when I turn it on and of does anyone no why
this is normal for most tvs . the click you hear is a relay that turns power on / off to parts of your power supply
please post your make / model and exact fault taking note of any flashing led's these normally flash out refrence codes that tell you what fault is on the tv
May 15, 2012 | Toshiba Televison & Video
Where is the gas cut off relay on a 1988 190e benz
The relays are located in the central electrics unit behind the fuses and in an additional holder just to the front of the main circuit. This particular one I am not sure.
If you think it is suspect or a problem with the system turn the engine. If the relay is working you should hear a click as it is energised. Hearing this may lead you to it. Unfortunately if you don't hear the click the relay is beat and I am afraid I still cannot point to the exact location. If you do hear the click and still have a problem If it is being energised you have a problem with a component or wiring. I am not an expert but I hope this helps.
kgnmce.
Mar 05, 2010 | 1988 Mercedes-Benz 190
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
Sony XBR 40" tube 2003 purchased
Soouds like the High Voltage board. It can be repaired. I did mine for liek $16. Ordered to chips soldered them in and viola, TV.
Scott
scott@vzandt.net
Jun 02, 2008 | Sony KV-36XBR400 36" TV
42pf9956/37 philps plasma
I don't know why but this got my TV on.
I took off the back cover and found the source of the clicking.
Two blue plastic rectangular relays in the exact middle.
When I pushed the power button, I felt the top relay click, and I saw a flash from the bottom one. (they are right next to each other)
I took a hair dryer and placed it over the two relays for about 1 minute and tried the power.
It clicked only 4 times and then came on!!!!!!!!!
For some reason heat helps the relay.
If anyone is a tech and can explain this, please do.
Good luck!!!!
My tv is on and it didn't cost me anything.
I just can't turn it off now!!!
Sep 25, 2007 | Philips Magnavox 42MF521D/37 Television
Tv was working fine...then shut itself off.
there is no reset button on any tvs that stop in 1980s when they no longer used tubes in chassis,s now the only tube is your picture tube. you probly have a shorted hori out put transistor.
Nov 21, 2006 | RCA F27242GY 27" TV
No picture or sound
If you had a burning smell, well the board is toast. These sets are made to replace the entire board at one time. Before installing the replacement module, the picture tube should be checked. A defective picture tube ( such as a G1 short) may cause a failure in the power supply section.
Sep 07, 2006 | Zenith C32V36 32" TV
Philips TP3284C 32" TV Logo
62 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
