Question about Fuji FinePix A345 Digital Camera
Shutter release button falls out - Fuji FinePix A345 Digital Camera
  • 2,517 Answers
Location which may have damaged. Please visit service center.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Posted on Feb 01, 2010
No image was shown on screen while i still can take photo.
According to ehow:
Turn off your Canon 1000D and remove the memory card, lens, battery and time/date secondary battery. The secondary battery is a small, round battery about the size of a dime found in the same compartment as the main battery. It is located in a vertical slot. Slide out the secondary battery by pressing your finger on the battery and pulling it toward you.
  • Place the body cap on your camera to keep dust out. Attach the front and back lens caps on your lens to prevent scratches and other damage.
  • Let the camera sit for 20 minutes. This will clear the camera's memory.
  • Place the date/time secondary battery and a fully charged primary battery in the camera and turn it on.
  • Press the shutter release button (the button you push to take a picture). If you are still receiving an Error 99, the problem is most likely caused by the camera body itself. The camera body must be serviced by a professional camera technician.
  • Turn off the camera and insert the memory card. Turn the camera back on and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the memory card. Turn off your camera and insert a different memory card. Turn the camera back on and press the shutter release again.
  • Turn off the camera and reattach the lens. Turn on the camera and press the shutter release button. If you receive an Error 99, turn the camera off and remove the lens.
  • Turn the camera so that it is face down, and gently clean the lens contacts on the camera body with a number 2 pencil eraser or soft cloth. The lens contacts are the eight small, gold pieces on the bottom of the lens mount. Be careful not to let any of the eraser scraps fall into the camera body.
  • Turn the lens so that the side that attaches to the camera is upside down. Use the eraser or soft cloth to clean the lens contacts on the lens, being careful not to let any eraser scraps fall into the lens.
  • Reattach the lens to the camera. Turn on the camera and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the lens. Take the lens to a professional camera technician for repair.
  • May 11, 2011 | Panasonic Lumix DMC-FS4 Digital Camera
    Every time I turn on the camera it sais Error 99 could anyone explain it to me .thanks chris
    According to ehow:
    Turn off your camera and remove the memory card, lens, battery and time/date secondary battery. The secondary battery is a small, round battery about the size of a dime found in the same compartment as the main battery. It is located in a vertical slot. Slide out the secondary battery by pressing your finger on the battery and pulling it toward you.
  • 6 Turn off the camera and insert the memory card. Turn the camera back on and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the memory card. Turn off your camera and insert a different memory card. Turn the camera back on and press the shutter release again.
  • May 11, 2011 | Cameras
    My Nikon D60 "Error. press shutter release button
    Hi
    The error is with the shutter release button and the unit has to be taken apart....Get it repaired by Nikon it is a common problem with these units.
    Thanks for using FixYa
    Have a Nice Day
    Jan 25, 2011 | Nikon D60 Digital Camera
    Nikon d90, blinking "Error"
    You "release the shutter" by pressing the shutter release button, often called the shutter button. That's the button you press to take a picture :-)
    The camera may or may not return to normal after that. If it doesn't, remove the battery, then put it back in and turn the camera on again. Try removing and reattaching the lens (with the power off). If the problem persists, have a certified Nikon tech look at it.
    Feb 18, 2010 | Nikon D90 Body Only Digital Camera
    Error code says press shutter release button again
    I e-mailed nikon for this same problem. Their solution was to take out the memory card and press the shutter release button in the demo mode. To get to the demo mode you first need to go to custom menu/controls/no memory card?/press ok/ arrow down to enable release and press ok. Now you are ready to try solving this problem. Press the shutter release button to see if it will reset the shutter release button. I haven't tried it yet but it is worth a try.
    Aug 25, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
    When i take a pic,it says error press shutter release button again
    Aug 24, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
    Nikon d40x shutter stuck
    The manual (pg 112) simply, and unfortunately, states this message "Press shutter release button again. If error persists, consult with Nikon-authorized service representative".
    Some questions that might help: have you had the camera in some extreme conditions, damp, sand, etc. Clean the shutter button really well. Maybe use a small air blower and clean in the shutter release creases.
    In the end, if the error continues, it will need to be serviced.
    Dec 28, 2008 | Nikon D40x Digital Camera
    Shutter release
    take it back to the shop
    Aug 06, 2008 | Pentax *ist DS Digital Camera
    Shutter-release
    After the focus is confirmed, the Shutter-release time lag for the DiMAGE E201 is approximately 0.4 second. If the shutter-release button is depressed in a quick motion without making any pause to confirm focus, approximately 1.9 second is necessary.
    Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
    Fuji FinePix A345 Digital Camera Logo
    43 people viewed this question
    Top Fuji Cameras Experts
    Steven Wander
    Steven Wander
    KJ Soni
    Level 1 Expert
    Jerry Greenberg
    Jerry Greenberg
    Are you a Fuji Camera Expert? Answer questions, earn points and help others
