Question about Samsung CLP 300 Laser Printer
The Red light is on and the back of the printer is far too hot
  • 526 Answers
If the red light is on and one of the colors light is on too.
that means that that toner is empty. if the main light is blinking, it means that that toner is low.
please check your user manual on page 6-8
thanks adi
Posted on Dec 12, 2009
I have a Xerox Phaser 3124 and I have refilled the tonner. My problem is that it is shown to me "TONER LOW" and LED is still red. It keeps printing papers but the quality is very low. Please...
When the toner cartridge is near the end of its life span:
• White streaks and light printing occur.
• The Error LED blinks red.
If this happens, you can temporarily reestablish print quality by
redistributing the remaining toner in the cartridge. In some cases, white
streaks or light printing will still occur even after you have redistributed
the toner.
1. Open the front cover.
2.Pull the toner cartridge out.
Caution
• Avoid reaching too far into the printer. The fuser area may be
hot.
• To prevent damage to the toner cartridge, do not expose it to
light for more than a few minutes. Cover it with a piece of
paper, if necessary.
• Do not touch the green surface underside of the toner
cartridge. Use the handle on the cartridge to avoid touching
this area.
3. Thoroughly shake the cartridge 5 or 6 times to distribute the toner
evenly inside the cartridge.
Caution
• If toner gets on your clothing, wipe it off with a dry cloth and
wash clothing in cold water. Hot water sets toner into fabric.
4. Hold the toner cartridge by the handle and slowly insert the
cartridge into the opening in the printer.
Tabs on the sides of the cartridge and corresponding grooves
within the printer will guide the cartridge into the correct position
until it locks into place completely.
5. Close the front cover. Make sure that the cover is securely closed.
Jun 02, 2011 | Xerox Phaser 3124 Printer
Red Light
reset printer or replace new cartridge
Jun 29, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP300 - All LED lights red and getting very hot when on
drl1069.dyndns.org/Public/CLP-300.pdf Ok above is your service and repair manual, inside is all troubleshooting procedures used by the engineers to troubleshoot and repair these units.
May 11, 2010 | Samsung CLP 300 Laser Printer
Red light staying on
I have my printer for over 2 years now and the red light regularly lighted up. So i opened the printer a few times, I shook the toner, unplugged the printer.. And this always worked.
Last week even that didn't do the trick anymore, so I was looking online what the problem could be.
Turns out, all you have to do is take the far left disposable canister out. (the little handle on the far left) Throw out all the toner that's in there, and plug it back in. (The canister is like a waist bin and it was full)
Now the printer is doing just fine.
Feb 08, 2010 | Samsung CLP 300 Laser Printer
The back and rear panel is quite hot and the ubit will not print
Install a smart panel software from samsung. you will get exact error.
Nov 19, 2009 | Samsung CLP 300 Laser Printer
Two red lights blinking
The flashing red light next to a page and bin indicates paper or a CD/DVD has jammed in the printer.
The flashing red light next to the drop indicates that the ink is low - if it is solid on then the ink is out.
Both of these lights flashing rapidly together means taht the print head carriage is obstructed by jammed paper or some other material and cannot return to the home position. Turn off the printer then open the paper support and the printer cover. Then remove any paper or other obstructions from the paper path by hand / tweezers. Then, turn the printer back on and the fault should clear. If the lights are stioll flashing then check the paper path again and see if the print head carriage assembly is jammed by gently moving it very slightly along the carriage. Don't force this or do this too hard or too far as you can cause some damage to the drive
Sep 11, 2009 | Epson Stylus Photo R200 InkJet Printer
Cpl300
mine is the same way, to solve this I elevated the bottum by 2 inches, then i kept it off, also i blow a fan on it while running.
also, you need to clean the filter (the gray "L" inside) black dust should come out.
lastly, mine actually broke because it overheated.
matt
Apr 20, 2009 | Samsung CLP 300 Laser Printer
The paper only feeds part way and then stops. Red light comes on
Following a suggestion on another post, I tilted my printer so it is at a slight angle backwards, higher at the front. So far this has worked.....
Nov 12, 2008 | Samsung ML 2010 Laser Printer
Zebra Printer TLP 2844-Z - Will not print from application - prints SM 10 53 4D
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Oct 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Epson Styluss C 66 problem will not print red light goes on
Epson has an interactive troubleshooting guide on their support site. http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp From the link above, choose your model printer. You will then be brought to the main page of your printer. Then, click on the "interactive help program" link under the Troubleshooting Guide section. Through this, you will be able to find an article describing what all the indicator lights mean and how to possibly resolve the issues.
Sep 21, 2006 | Epson Stylus C66 Photo InkJet Printer
Samsung CLP 300 Laser Printer Logo
330 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
