Question about Gateway FPD2275W LCD Monitor
Samsung monitor 591
I have samsung 591 monitor. It has a problem that the relay is in oscillating condition.It does not have stable state giving the sound "cut-cut'
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
Monitor keeps on blinking in regular interval
This can be possible fault with the output circuit as the blinking is in oscillation. Also with many sets when it goes old as there is a high possibility that the components over a period of heating and cooling , tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs.
Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
if not the fault can be poor capacitors- try heating to see if the oscialltions stop- or even failure of IC
Jun 17, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Sir i have 17' crt monitor and it gives display as shaking condition .. Could u give me some solution abt that ..
make sure u dont put speakers near ur monitor and any other electrical equipment that can generate magnetic field. (eg. UPS, stabilisers...).
May 19, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
MONITOR WON'T POWER UP
That will be my first place to check, see pictures of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 25, 2010 | Samsung 206BW Monitor
Need monitor driver
You can download the driver by clicking here Thanks :)
Jan 23, 2010 | Samsung SyncMaster 760vTFT Monitor
Power not wrokign properly
check secondry side of sm txr for shorting
Jan 10, 2009 | SAMTRON 55V 15" CRT Monitor
Philips 17 inch 170s4fg lcd monitor,display flickering
I have Got one philips 170S lcd monitor. Iam having flicker peoblem and my display not stable. pls, give me ur best solution for the above problems.
Jan 10, 2009 | Philips 170S4FG 17" LCD Monitor
Monitor problems
gand maro gute khao...............
Sep 07, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Distortion in Monitor
Your problem is simply a leaky capacitor on the vertical oscillator circuit on your monitor. Try replacing the ones with 10uF values.
Aug 10, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung, SyncMaster 1100MB
Hi idil that is very simple
in only 4 conditions the monitors shakes like that they are
1. Give 1 feet gap between speakers and the monitor
2. Give 1 feet gap between Ups and the monitor
3. Give 6 feet gap between all the radiation things
4. Check the power voltage up and downs
Thank you
Apr 16, 2008 | Samsung SyncMaster 1100MB 21" CRT Monitor
Samsung 591s monitor
It isn't getting a steady, usable source of power, you can try to diagnose this your self but it will be a power issue INSIDE the monitor within the circuit board
Jan 22, 2008 | SAMTRON 55V 15" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
47 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
