Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Actual Model Numbers are necessary to correctly diagnose the problem. Does the agitator also move when spinning?........Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Actual Model Numbers are necessary to correctly diagnose the problem. Does the agitator also move when spinning?........
You can't post conmments that contain an email address.
Those parts you can check 1/ strings holding the drum were broken causing drum unbalancing when it spins. 2/ Drum bearing also gone. (noise) 3/ 3 slides that located underneath the triangle frame need replaced.
Lol, the spin cycle on them is so powerful it will walk around your uitlity closet. Unly suggestion is to use wood or some other wedge to make a tight squeeze between the machine and the wall. This will keep the spin from allowing the machine to move or make loud noises.
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
