Question about GE XL1800 1100 Watts Microwave Oven
Microwave dying Whenever I try and use our microwave, it will start to work, then after about 10 sec the screen will flicker and make odd noises, then it shuts off. It comes back on, and says 'Check food' and 'Power loss' or something similar. My best guess for this is a worn/dead fuse, but I really have no idea. Our specific model is JVM1870CF
  • Tortel Jan 24, 2008
    Yeah, this has been happening less more recently. The one thing I can think of that may have caused this is a magnet that was on the side right next to the screen. I moved it, and now it seems to be fine.
  • 770 Answers
Next time set a cup of water inside and set it for 1 min press the start button then hold the door in see if it runs thru the cycle let me know
Posted on Jan 24, 2008
Microwave heats, light come on, turntable turns, door opens/closes properly, but when heating food it starts buzzing and flickering
Replace if you are not in to DIY, sounds like the inside of the cabin has been compromised and it is now arcing. or watch this You tube video, can potentially be a fix
https://www.youtube.com/watch?v=EZmKTpaAUUQ
Dec 18, 2017 | In Microwave Ovens
My microwave would not turn off. Door closed and light/turntable off, the microwave continues to work when not selected on.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Microwave.
Mar 09, 2017 | Whirlpool GT4185SK Microwave Oven
Jenn air microwave JMV 916 BAS won't power up
The magnetron has probably shorted, and in rare cases the power transformer will fail, "but unlikely"
Mar 27, 2012 | Jenn-Air JMV8000 Microwave Oven
I have a panasonic convection/microwave. Last night, after I cleaned it, using oven cleaner on a sponge, it made a loud humming noise after running on microwave for about 10 sec. It does not make the noise...
Since the unit makes the noise on Microwave but not convection it is a problem it he Microwave Circuit. Probably in either the rectifier of bad mag, one of them shorted. Just looked at the date you posted this, Im sure you have fixed or replaced this by now
May 31, 2017 | Panasonic NN-C980 Convection/Microwave...
Flickering
Magnetron is bad/shorted. Not economical to repair. Replace microwave.
Sep 14, 2017 | Whirlpool MT2110SJQ 1100 Watts Microwave...
GE PVM2070SMSS Microwave, Unit runs for a sec then shuts off.
Obvious thing is to try plugging in a different receptacle to verify if it might be bad wiring in your kitchen. Make sure to use a different circuit, maybe in different room. If it is the circuit, then likely cause is those plugs with push in back wiring. Replace with ones that wire screws to.
Aug 28, 2009 | GE PVM2070SMSS Microwave Oven
Turntable won't spin so microwave won't heat
Is it possible to take the glass plate out, if so, please remove the glass plate, switch on the microwave for 10 secs and watch through the door to see if you can see the centre spindle turning round? Try this and get back to me please
Mar 12, 2009 | Goldstar MV-1615 Microwave Oven
EVERYTHING WORKS NO NOSIES SOUNDS LIKE IT IS WORKING WILL NOT HEA
could be the power fuse inside the microwave, you have to remove the casing to access these.large power fuse would seem to be the problem, this is normally 10 amps but could be 13 amp. there is also a control fuse that control the power relays
if this is blown the relays could be at fault
Feb 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
...have Danby 1.0 cu. ft.
When talking about "Power Level", there is a misconception that the cooking power is being adjusted. This is not the case. The user is actually adjusting the duty cycle of the Magnetron. For instance at 30%, the Magnetron will be turned on for 20 sec. and off for 40 sec. A loud 60 cycle hum is usually caused by a shorted Magnetron. Thus the unit is not economically repairable.
Sep 30, 2017 | Danby Microwave Ovens
GE Spacemaker making odd noise
We are having the same problem with our XL1400. I suspect it has something to do with the turn table but don't know for sure. We would be willing to disconnect the turn table...anything to stop the noise but don't know how.
Mar 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
138 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
