Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
I bought jabra bluetooth handsfree. but it not connecting with motorola l7i. so plz provide me any solution..
  • 638 Answers
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Posted on Jan 05, 2010
I tried my best. bt i couldnt connect my nokia n73 with bluetooth handsfree...plz provide me solution for this...how to connect...
in most nokia N series, you will have your handsfree device paired to your cellphone. it also depends on your handsfree model. some bluetooth handsfree models are not compatible with nokia N series. Jabra handsfree models are compatible with nokia phones. best buy.
Nov 01, 2010 | Cell Phones
I have a jabra ote3 bluetooth. i don't have the manual. can i connect the bluetooth to a verizon motorola razor?
Yes,You can connect the Jabra head set to motorola razor.
Please follow the steps to connect it to motorola razor
1. Turn headset off. Press and hold until solid light comes on.
2. Activate Bluetooth on your phone.
3. Search for Bluetooth devices and select Jabra BT2070.
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 .
Thank You
Aug 11, 2010 | Cell Phones
My bletooth h350 handsfree device needs a pass code for my phone to accecpt
All the motorola bluetooths that i have had that needed a passcode used "0000". See if that that works. Good luck!
May 28, 2009 | Motorola Mobility H350 Wireless Headset
Don't know how to work bluetooth for my mobile!
i'd like to know how to set my motorola bluetooth h700 to my motorola i776w mobile phone.
Mar 25, 2009 | Jabra BT2020 Bluetooth Cell Phone Headset...
BlackBerry won't pair with device anymore via Bluetooth
1. Go to Options/Bluetooth
2. Select device found
3. Select device properties
4. At Trusted select yes
It'll never ask again
Dec 30, 2008 | RIM BlackBerry Curve 8310 Smartphone
How to use your handsfree device with your phone
ur hands free is easy to use...u vil just have to plug in the hands free accessory to ur mobile into the given socket.
if u r using a bluetooth device, u vil have to active ur bluetooth in ur mobile and star search, simultaneously u vil have to swith on ur bluetooth too..in ur mobile u will be asked if you wud want to bond with the device..it might also ask for a passkey which is normally 0000...once u r done ur bluetooth vil be ready to use. if u r having more problems or need more assistance..plz update me...also let me know the model no of ur mobile and bluetooth/handsfree.
Thanks for using Fixya
Jul 16, 2008 | Motorola Mobility Rugged Cordless Shop...
Connect jabra to blackberry
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select BT150 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
May 19, 2008 | Jabra BT150 Wireless Headset
Bluetooth handfree not working
Verify that your Jabra BT headset is turned on. You might need to "discover" the device as well.Your RAZR should have instructions on how to pair devices.
Apr 30, 2008 | Motorola Mobility RAZR V3
Pairing a Jabra 250 headset with my new motorazr2
Here is what you need to have configured on your phone for Bluetooth connections:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
Dec 14, 2007 | Motorola Mobility RAZR V3
Connecting a Bluetooth handsfree with the W880i
Hi, (1) Press & hold the switch of the Bluetooth handfree. (2) Now search throw ur handset via blue tooth.
Aug 26, 2007 | Sony Ericsson Walkman® W880i Cellular...
Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
55 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
