Question about Tascam 112 MKIII Dual Cassette Deck
I have 2 and neither will play a tape. When you press play both make a strange noise
  • 117 Answers
Is it the same tape every time or all tapes? If it is all tapes then it's more than likely a belt issue. The tape players have little rubber belts inside they sometimes get stretched when they are used alot. And they will make a whinning sound. They can be replaced.
Posted on Dec 12, 2009
Tascam 302 Tape Deck - When I press play it rewind/fastfoward
There is either a cam belt that is lose or the flywheel assist can not move the head base due to hardened grease. It needs to be serviced.
May 16, 2013 | Tascam 302 PRO DUAL CASSETTE DECK Single...
BOTH doors jammed on TC-WE605S
Some tape decks are belt-drive. If the belt is worn, it will either break or jump the cog and you will experience these kinds of problems. That's what happened with my Sony ES deck recently and I couldn't even eject the tape until I got the belt replaced.
Jul 30, 2009 | Sony Audio Players & Recorders
How do I record from one tape deck to the other?
Put your "blank" in the deck with the record button, normally red button and press rec/play and pause at the same time, put your "origional" in the other deck and press play and pause at the same time, then un-pause both at the same time. Make sure that the hifi is set to tape as if you record tape to tape when listening to radio foe example, you will get a strange "mix tape" of your origional and the radio.
Jun 05, 2009 | Audio Players & Recorders
Hi there Guys! Problem with Sony Camcorder DCR - TRV230E
Stuck sensor. Sounds silly but smack it.
Hit your camera several times with a flat hand (bottom, tape side). Its strange but it solved it for a lot of people. Firmly smack the bottom and then put the battery back on and give a it a shot.
Feb 02, 2018 | Cameras
Tape plays too fast on slowest setting
The tapes may have been recorded at 1/2 speed or 1/4 speed so they are not playable on this model.
May 16, 2008 | Panasonic RR-830 Desktop Cassette...
Noisy capstan which runs continously
most tape decks are designed so that the spindle will run when powered on. when you press play or record, the pinch roller elevates the tape to the spindle, tape starts to travel.
noise is basically from the mechanism, or deteriorated in time as yours is an used one. if you are lucky to find some good pinch roller rubbers of same diameter, replace them.
pc-cook
Jan 15, 2008 | Audio Players & Recorders
VWM-950
I suggest you get the Tape path cleaned up. Could be dirty video heads or a dirty Control Head. Use a good 'wet' type cleaning cassette.
Jul 03, 2007 | Sanyo VWM-950 VHS VCR
Playback sound
Unit might be picking up 60 cycle hum or other electromagnetic field. Is VCR sitting on/under another piece of electronic equipment? If so, it could pick up such from the power supply circuitry of that other device. Try moving the VCR away from other equipment and see if the unwanted sound disappears.
Mar 09, 2007 | Philips VR550 VHS VCR
Strange noise
Unusual noises that start after a mechanical device is dropped are never good regardless of the device. I would suspect that something is physically bent or out of alignment and continuing to use the camera risks additional damage. As to if you should still use it that depends on how much its worth to you and if you plan on repairing it later.
Feb 24, 2007 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Tascam 112 MKIII Dual Cassette Deck Logo
229 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
