Question about SonicWALL NETWORK SECURITY APPLIANCE NSA 2400 MULTI-CORE UTM APPLIANCE Firewall
Firewall as a switch
Sir, I am using Sonicwall NSA 240 and it is configured by the provider. Now i have 5 free ports in the same, i want to connect a laptop on free port like a switch. Is it possible in this firewall. Please give me a suggestion.
For Your Information, in previously am using Sonicwall TZ 190, and my laptop also connected in the same.
Thanking You in Advane
  • Anonymous Mar 14, 2014
    SonicWall NSA4500 Firewall how to check open and close port
    Problem Solver:
  • 10 Answers
Yes, there isn't anything wrong in connecting any extra computers on the free ports. Go ahead and plug in your laptop. If it doesn't work, then its the best time to ask here. ;D
Posted on Dec 12, 2009
I have restricted access to facebook on my network using sonicwall NSA 240 firewall by adding www.facebook.com in restricted domains. if someone tries to access it directly he is not getting the site. But...
Isn’t the internet great?
Well the way that these filters work is that they look for the EXACT address: www.facebook.com. To fix this you’ll want to add https://www.facebook.com and http://www.facebook.com. This will help the filter to see all combinations and block them all.
Let me know how this turns out!
Dec 16, 2017 | SonicWALL Inc SonicWALL NSA 240 Firewall...
What is MTU port no
Differs for each broadband supplier. 1400 is most common
Apr 15, 2010 | SonicWALL NSA 3500 (01-SSC-7016) Firewall
Problem in Sonic FireWall
Check with your ISP for whether they have blocked Port POP3 Port 25 or not. also allow (Open) this port in Sonic Firewall also.
POP3 Default Port 25 but many provider use different Ports so also make sure that you configured correct port.
Feb 26, 2010 | SonicWALL TZ 210 WLS-N TOTAL-SECURE NTWK...
I need to add an ip range to my sonicwall tz 170
This is not directly possible to do with a TZ170 as the device will only allow configuration for 1 static or dynamic IP at a time for the WAN port.
However this being the case, I suggest setting the SonicWALL up as a perimeter firewall and place devices that require the other public IPs form the additional IP range behind the TZ170. Basically the SonicWALL becomes the gateway for the other IPs needed as long as the range of the IP block is contiguous.
This would involve using the 4 ports of the LAN on the back of the TZ170 to connect directly to the other devices or if it is more then 4 devices, using a switch connected to the LAN side of the SonicWALL to provide connectivity to the multiple devices behind it. Most TZ170 are licensed for 10 connections on the LAN side and if you require more then 10, additional licenses will need to be purchased.
I would be careful pushing too much traffic through a TZ170 as it is designed for Small Business use and will quickly become overloaded with too much traffic causing high latency/traffic bottlenecks and in extreme cases connections being dropped. This is especially true for multiple VPNs.
Jan 23, 2010 | SonicWALL TZ 170 SP Firewall
How to setup up my cctv cam to sonicwall tz170
If your camera is connected to DVR then do the port redirection on your firewall so that you shall view the cameras from internet, If your camera is directly connected to network using RJ45 simply do the port redirection to IP address of CCTV camera.
Nov 19, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
How to routing router static ip address and local
Use the Sonicwall configuration wizard..
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
Apr 22, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
How to configure Sonicwall TZ 190? I have connected console to the Sonicwall and trying to open it via Console. But no configuration or prompt is coming. Kindly help ASAP.
open control panel and then add printers and other hardware, then up in left hand menu go to system then hardware, device managed and check if your driver is updated. if it says it's working properly then uninstall it and it'll pop back up reinstall then it should work fine.
Dec 03, 2007 | SonicWALL TZ170 (01-ssc-5740) Firewall
Open Questions:
See all SonicWALL NETWORK SECURITY APPLIANCE NSA 2400 Questions
SonicWALL NETWORK SECURITY APPLIANCE NSA 2400 MULTI-CORE UTM APPLIANCE  Firewall Logo
132 people viewed this question
Top SonicWALL Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Alun Cox
J John
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
