Question about Smeg Refrigerators
First gathered water at the bottom, thought that is was due to something touching the back. Stopped fridge, cleaned it, started it again. Light on but no familiar noice of the engine starting again. Engine felt warm, but no cooling inside the box. Motor or thermostat out of order? Modell s28STRP3, 90W, volume 247 l/21 l Any suggestion on how to spot which part is failing?
    Problem Solver:
  • 14 Answers
Don't know the model/brand off the top of my head...
But: If the compressor is warm/hot, but nothing is happening, I ask this:
Even if the fridge is not cooling, is the compressor running, or dead silent?
If silent, but warm, do you hear a "Click" every so often ? Maybe 3 to 5 minutes apart, followed shortly by a 2nd click ?
If so, most likely the compressor has seized, and this is the over-current trip acting (thermal, so it needs time to cool).
Big problem if it is the compressor (expensive).
The only other thing that might cause a similar occurrence, would be if the compressor has a Start capacitor. If this has died, the compressor will not turn - just sit there getting warmer, as the over-current trip acts.
If it was a dead thermostat, the compressor wouldn't get power, and would be cold.
Posted on Dec 12, 2009
Water under front of refrigerator
Dose water gather inside the fridge, if so, it may be the drain in the inside back of the fridge is blocked, try cleaning it through with a long pipe cleaner,
or if it has a water dispenser on the front, try removing the plastic plinth at the bottom of the unit and checking the water connection,
Good luck
Nov 12, 2014 | Whirlpool GI7FVCXWB (27 cu ft) Bottom...
Bad smell from motor
You need to remove any spoiled food from the refrigerator and clean the interiors with hot water added with baking soda. You need to clean the door seals and remove the breaker strips. Also check for unusual wet insulation.
Hope this work
Jul 28, 2010 | Amana ABB1927DE Bottom Freezer...
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
Hi, I have a side by side S20D RBB32-A/G Fridge Freezer with ice and water dispenser. The frezeer and fridge stopped working. I called a local repairer who took away a part for repair. However, the fridge...
Try checking the mesh screen which is in the water line where the water supply connects to the water inlet valve on the back. It can get stopped up with sediment.
Sep 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer working fridge not
There are screws around the edge to remove it. It's probably iced up due to defrost system failure. How to check everything http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Excess water inside fridge
Take a pipe cleaner and run it down the little hole. That is a drain hole and it has something clogging it, not allowing the frig condensation to drain.
Aug 15, 2009 | Hoover HCA390FFK Bottom Freezer...
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
F & P Fridge/Freezer Model N395B freezing under vege bins
While staying with a friend that had this problem we assaulted the fridge. Pulling everything we could apart. After finding this link http://www.stokes-aus.com.au/StokesAP/Manufacturer_Info/FP/FRIDGES/517579%20%20Series%20R%20N308R,308XR,325TR,369BR,375TR,395BR,400HR,4.pdf which had a parts list similar to the fridge we had. Pulled out the Defrost timer paragon located next to the compressor. After giving it a good shake it started making ticking sounds again. It appears that it is semi-faulty in our case and had stopped working.
Dec 04, 2008 | Fisher and Paykel Active Smart E522B...
Whirlpool Fridge has water leakage
have you been filling it up with more food than usual? how are you storing the food? if its touching the back of the fridge then this causes the water to drip down the back and accumulate at the bottom. I had the same problem (different fridge), I'd open the fridge and there;d be a pool of water at the bottom, sometimes it even started leaking out onto the floor.
so... i just made sure when i put food in that it wasn't all pushed to the back and that none of it was touching the back of the fridge - no more water at the bottom!
give it a try , hope this helps.
Jul 31, 2008 | Whirlpool Refrigerators
Chilled water stopped .chiller frozen in bottom of fridge
SR-32 EMB MODEL, FREEZER OK, BOTTOM NOT COOLING PROPERLY. ADVICE SETTINGS
May 28, 2008 | Refrigerators
Refrigerators Logo
226 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
