Question about Bosch Washing Machines
Water wont drain from wash. Wont spin or drain
Water wont drain from wash. Wont spin or drain stuck on wash setting. Cant get filter cap off.
    Problem Solver:
  • 14 Answers
Something will be jamming the drain pump (no surprise there).
Some Bosch w/m's have a base plate, some don't.
Pull the w/m forward & tip it back against the wall at >45 degrees - should balance there easily. See if you can get underneath (inside).
If so, (power disconnected), remove the bottom kick plate area, and drop the drain pump back internally & down. Remove the wires & pipes (slowly, if there is still water to drain), and remove the pump. Dismantle it & remove the obstruction.
If there is a base plate, try for all hell to get the filter cap off.
Otherwise, you will have to put the w/m on its back, and unscrew the base plate (often, not an easy feat, as the screws are very still & jam).
Then follow above instructions.
Posted on Dec 12, 2009
It most like the pump
Why has my machine not drained or Spun.
Cant be 100% but could be overloaded, turn off, set dial / program to spin and try again, may need several goes to empty.
Jan 13, 2016 | Washing Machines
Elba washing machine wont drain or spin
The pump filter is blocked ,so it wont empty,remove filter cap and clear out lint, coins etc.
Jan 03, 2014 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
WHY WONT MY GENERAL ELECTRIC MODLE #WCXH208VOWW SPIN
Hi Darryl
Usually won't spin until water is drained to a low level.
Wont drain possibly because of blockage or pump blocked or stuck. (A Common Problem in Washing Machines)
So... As for further Troubleshooting
Process of elimination.
Where is Time Wheel set and what does it require to advanced to next stage.
Think of it as a Rotating Timer Switch stopping at each stage to check conditions.
The stages are controlled by sensors like "High Water Level"
The Sensor could be a simple Float Switch... eg. "High Water"
If water is High... Dont allow door to open and don't allow spin.
But do allow Pump to run.
It's all Plain Logic like used in computers (If, Then, Else)
Also Known AsTruth Tables
Good Luck
Truth Table Examples
Jan 04, 2013 | Washing Machines
Hi my washing machine wont finish its cycle it is stuck in its final spin ? i cant open the door and cant find the filter
These are my general guidance notes for similar problems just in case ;-0)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 22, 2011 | Hotpoint Aquarius WD640 Front Load...
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Wont drain,spin,or agitate
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Dec 27, 2008 | Maytag PAV2300 Top Load Washer
Cant drain and cant open the door
Jun 26, 2008 | Creda W100FW Front Load Washer
Fisher & Paykel no spin, no rinse
hums sound proble coming from the drain pump. sounds like its trying to pump out water but cant. try tipping back andsee if you can spin the pump manually, (usuallya fan cooling blade coming outta back end of pump.wont spin if it cant drain
Mar 22, 2008 | Washing Machines
Washing Machines Logo
289 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
