Question about Toshiba 42H81 42" Rear Projection Television
The screen wiggles and jumpes around like a srcambled chanel
The menu is clear,but the picture itself looks scrambled and the color is fine,i cant figure it out please help me!
  • Toshiba Master
  • 8,617 Answers
That sounds like it could be the hyper module causing the problem. It usually caused by bad capacitors on that board.
Posted on Dec 12, 2009
SOURCE:
How do I fix the picture
There are two common problems on this model that have very simiar symptoms.
The first problem is known as Convergenvce problem. This is when the colors are not aligned, look 3D, etc. When this occurs the colors wont jump around or look jagged...instead they just look overlapped, warped, 3d, etc...
The second issue which is the one I believe your set has is known as a hyberboard failure....When this happens the tv video will move around...look jagged or scrambled, etc....also...sometimes the TV will shut down....
Both of the above can be repaired with parts or kits from sites like www.TvRepairKits.com
Apr 27, 2013 | Toshiba 57HDX82 57" Rear Projection HDTV
My sony wega kf-50we610 unlike every one else i have no problems with set turning on my problem is i cant watch anything do to the picture being distorted scrambled like i can see the menu options and...
It looks like the vidoe board but the fault can be also a distortion in the horizontal / vertical section. So check the PIN amp and related sections. What must be looked is of the HSTAT can be off set.
Deguass the set well to confirm if there is any possibility of a distortion of picture by a severe magnetic field.
Since there can many problems associated with a distorted picture but you can try and see these possibilites other than the Y amp processing. Hope my suggestions helps.
Aug 20, 2010 | Televison & Video
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
Screen is srcambled
Hello
In the cause of dropping the phone,the FLEX shifted from its original position.
A flex is found in Flip phones and slide phones,it is what connects the screen of the phone to the panel of the phone.
What you should do is this;
.open your phone
.you will see something like a little wide plasticlike cable (that is your flex)
.remove it and fix it back properly (be careful) you should hear a click sound
.close the phone and switch it on,you wont have a scrambled screen anymore
if you cant do this yourself,get somebody with a bit of experience to do it for you
Thank you for visiting fixya
Feb 22, 2010 | Pantech C470 Matrix Smartphone
Picture green and not clear, getting smaller, shutting itself off
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
Convergence is scrambled due to power outage. how do i use remote control to get into service mode to do a "course convergence adjustment" ?
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Your TV may have one or more of the following symptoms....
Dec 10, 2008 | Panasonic PT-47WX53 47" Rear Projection...
VCR won't play ..screen says"NO SIGNAL
I had the cords pluged in backwards goin out instead of in, Duh. Working fine now!
Dec 08, 2008 | Memorex MLT3221 32 in. LCD TV
When I want to watch something whether it be Cable, a movie, or video games the screen only stays clear for 4 seconds then it scrambles. Not only that, jumps from being scrambled to going to "no...
you have to go into the settings of the video card and change the "signal" from the one you are using now, this could be RGB, S-Video, Composite, Digital or Analogue, flick through these settings until you find the correct signal
kind regards
Nov 25, 2008 | Computers & Internet
Picture distorted
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Mar 08, 2008 | RCA P46812BL 46" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
125 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
