Question about Cell Phones
Mobile problem I have a model ZT-C 1000, the following problems i am facing :1. FM Radio is not working, although i can hear loaded songs through Audio player2. Television is not working.3. The phone automatically swithced off for several times in a day.regards shinde vijayIndia
Toyota-56037 radio (FM/AM) malfunctions..like... the system receives FM signals 76Mhz to 90 Mhz only although there are a lots of channels after 90Mhz. How to reprogram it? Plz help. TAUFIQ
if there is a mode button , press that and there is fm 1 whch is what you have , press again and you get fm 2 press again and you get fm 3
each fm number is a band width so select the band width that has most pf your stations and then auto select on it
if you have the owners hand book , the procedures are in ti for setting the radio
Nov 17, 2015 | Audio Players & Recorders
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 | Apple iPod touch
Hi, i own a Sonilex SL-003FM portable speaker and wants to know how i can play FM in it... I am able to play songs from USB, mobile, SD and PC but unable to play FM in it.
Hi ,On the unit and donot put usb or sf card unit will automatic catch fm radio,make your there is fm radio signal is there,if still fm cannot connect that mean unit is having problem,Then go to the seller,Where you bought this .Rgds Sonilex Team.(China )
Jul 09, 2011 | Audio Players & Recorders
I hav a nokia 2626.wen i insrt the air phn car kit sign is shown n i cant play the fm radio although i can talk using air phn so plz helm me out hw do i listn fm radio?????
if you use other brad hands free so your fm radio not work properly because your hands work as antenna also. its only possible when you use branded hands free.
May 07, 2011 | Nokia 2626 Mobile Phone
Following a flat battery, my cd player won't work.
You dont need a code if your radio is working but your cd isnt. You just need to reset the cd player by finding a little small indent on the face and push it in with a sharp pen, pencil or paper clip. Some reset buttons are also found when you remove the face of the radio. You will notice it when you see a little small round hole. Push it in for at least 2 or 3 secs
Apr 08, 2010 | JVC AM FM CD DET FACE CAR STEREO
Mobile ZTC problem
try to check the port of battery, have that problem as well.
Dec 12, 2009 | Motorola Mobility i880 Cellular Phone
Sandisk 240m mp3 not playing
the radio and mp3 uses one audio amplifier, check if you have loaded your music with mp3 songs, if not load with mp3 songs. if songs used to play and just stopped playing, then follow these steps,
i does your display show song playing, if it does then your set is fault, and if it doent and display unsuppoted, load with mp3 songs.
ii if it was playing and just stopped, than take it to a tech, who can open it and check the change-over switch, or selector of that set.
iii the problem is to very big.
Mar 30, 2009 | SanDisk Sansa m240 MP3 Player
Does not support few songs format
Make sure the songs are unlicensed
May 10, 2008 | SanDisk Sansa e250 MP3 Player
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
