Question about Philips 27PT5441 27" TV
Led flashes 11 times then 3 then 2 then 1 - Philips 27PT5441 27" TV
  • oleen1 Dec 12, 2009
    how do I fix this?
  • Philips Master
  • 1,230 Answers
North of the flyback is a 160 or 200 volt cap at 1MF to 4.7MF at 85 degrees. Replace with same capacity but use a high temp cap rated at 105 degrees. This is a very good start for repairs. I have not repaired one in somtime, so cannot give the exact locations or values. But it always the 160 to 200volt cap with less than 10MF that go down...good thing the caps in this set are only few! Find a hobbiest to fix this for you! Quick note as well replce the cap behind the flyback too. It is a 100volt 10 Mf . This one almost always goes on the fritz...take extra caution and not to much heat or you ruin or destroy the PC traces. Good Luck and be careful!!!!
Posted on Mar 09, 2010
  • matt martin
    matt martin Mar 09, 2010
    You will have to install a horizontal kit #4835 310 57673
  • matt martin
    This will correct the horizontal timing and everything will come on at the same time. This is factory approved.
  • 3,741 Answers
Its the problem in the internal board the power supply board is getting short due to some faulty components on it. you will have to check out this with multimeter and replace the faulty components. you can get the required parts at www.radioshack.com or at www.partstore.com thanks.keep updated.
Posted on Dec 12, 2009
  • 3,230 Answers
Well this indicate failure/loss of Horizontal Drive. Horizontal drive is responsible for developing the high voltage necessary for lighting the picture tube.
post further comments if you need more help or information....
Thanks
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
I am trying to unlock the region code for Sony BDP-S5100 with the URC7740. The hack program refers to "press and hold the &#147 key. Where or what is "&#"?
I would have to guess, that is probably not the correct remote. I feel I must inform you, trying to upgrade your firmware, from an unsavory hacker, can turn your unit into a brick(doorstop). IMO, proceed with caution.
Jan 14, 2015 | One For All URC 7740 Remote Control
Why does my acer aspire e1 571- 6482 not start or charge anymore? only the on led and batt led flash.
pressing power on button should be for 30 to 40 sec but the flashing lights means there is a hardware problem can find flashing light codes on the net you could try removing ram 1 by 1 c if that works hope this helps if not will keep an eye on this
Jul 29, 2014 | Acer Aspire E1-571-6650 Laptop
I have a flashing orange light and cant find the manual, I have changed the inks but its still flashing?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 02, 2010 | Canon Office Equipment & Supplies
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
Sony FD Trinitron WEGA Tv - LAMP blinking 11 times
Sony tv has self protection program. The red Led blinking light indicate the probable cause location. For this model it is either 2,4 or 5 flashes every 3 second. Please check the blinking again
Feb 09, 2010 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Panasonic PT-47WX42F does not come on light flashes 3 times HELP!
There is a service manual which should cover this model/chassis series:
Elektrotanya for electronics experts
(PDF format - free - no sign-up needed - 100% clean)
Page 11 ('auto diagnosis feature') shows a table of LED flashes and what each one means. I'd start by checking D-board (since that is power and deflection) and going from there.
Dec 21, 2017 | Televison & Video
I tried several different cards but no luck. Cards work ok on other computers.
5V Stand-By Indicator LED
The power supply will always supply a 5V standby voltage to your
motherboard so that it can power on via for example Wake On Lan
technology. This LED shows that your power supply is supplying
this standby voltage to your motherboard.n :D
You may need to replace your power supply, if the LED is flashing, it's not supplying the power the motherboard needs.
[JP-25]
1 2 3 4 5 6 7 8 9
10 11 12 13 14 15 16 17 18
1] Power Led (+)
2] --
3] Power Led (-)
4] --
5] --
6] Speaker (+)
7] --
8] --
9] Speaker (-)
10] Reset switch
11] Reset switch
12] N/A
13] Power Switch
14] Power Switch
15] ACPI Led (+)
16] ACPI Led (-)
17] HDD Led (+)
18] HDD Led (-)
For future reference you can download your motherboard manual here:
(PDF) Soyo K7VKP2
May 09, 2009 | Computers & Internet
Philips 27PT5441 27" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
