Question about ASUS Computers & Internet
Can i put 3 pcs if 1gb ddr1 pc3200 or 3 pcs 1gb ddr1 pc2700 to ASUS a7v8x-x FSB is 200/266/333Mhz? I'm using AMD athlon xp 2200+ not sure of the FSB of the processor cause I'm confused about the note:'' PC3200 max 2 banks only PC2700 max 4 banks''
    Problem Solver:
  • 17 Answers
If you put 4 3200 it will be powered down ( Underpowered to 2700 ). This is due to the multiplier in the bios. so it just depends really on the speed of the processor you want coz it will cause it to drop if you do that to match the new Mhz of the ram inside the machine. You could of course over clock the machine a little to bring the power up a smidge. you just need to check what the max ram is on your machine this will ultimately make the decision for you. ALSO MAKE SURE THERE ALL THE SAME MAKE,SIZE,SPEED otherwise Duel or Quad Channel will not work and the machine will not work as well as it could. if you have anymore probs you can reach me on dan021ny-at-hotmail.co.uk
Posted on Dec 12, 2009
How do you know when a memory stick is single-bank? I want to upgrade my A7V8X-X with 3 Gs, but I keep getting confuse how to determent what is single-bank! Is there a specific code in the product...
This is the memory spec for your motherboard...
3 x DDR DIMM Sockets
Max. 3 GB unbuffered PC2100 / PC1600 non-ECC SDRAM Memory (PC3200 Max. to 2 banks only / PC2700 Max to 4 banks only)
Part of the memory spec will tell you if it is single sided (memory chips only on one side of board)
Double sided is memory chips on both sides of the board....Some systems will not work with double sided memory...
Feb 10, 2011 | ASUS A7V8X- X VIA KT400 ATX AMD AUDIO LAN...
Is it possible that AMD Athlon II X2 (3.0ghz) processor will fit in in this ASUS A7V8X-X motherboard?
hello there,
  • Socket A CPU support Type,
  • models Athlon, Duron, Athlon XP
  • The AMD Athlon II X2 is a Socket AM3, sorry to tell you that this motherboard and CPU will not work together correctly. New motherboards are always fun
Jan 27, 2011 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Abit NF7-s - hynix ram support problem
The problem probably is you mixing fsb speed, all the cards should
be pc3200 or all of them should be pc2700.
You don't mix.
Feb 13, 2010 | Computers & Internet
I have asus K8V-vm and i installed vista home premium which is working very well but when i try to install any kind of games or any software it do not support it.What should i do!
switch to xp pro sp2..
i guess ur using ram over 1gb..(though it may support upto 2gb ddr1 400/pc3200 fsb probably)!!
replace it with a standby n check..it may b a faulty ram..
make sure ur system clock speed is matching..
if ur using more than 1 ram, both must b of the same frequency..(eg 400fsb+400fsb / pc3200+pc3200 [correct]; 400fsb+333fsb [wrong])..
check if ur hdd is working fine and without any humming or oscillating noise..
also go for a bios update frm: http://support.asus.com/download/download_item.aspx?product=1&model=K8V-VM%20Ultra ....
..if ur not professional, do contact ur system admin/vendor....
Oct 26, 2009 | ASUS K8V-VM Motherboard
Memory ram
According to SiS® official document, SiS® 748 chipset has limitation DDR supports:
CPU at FSB 200MHz mode, it will NOT support DDR400
CPU at FSB 333MHz mode, it will NOT support DDR200
CPU at FSB 400MHz mode, it will NOT support DDR200/DDR266
Depends on chipset http://www.asrock.com/mb/overview.asp?Model=K7S8XE
Jul 22, 2009 | Computers & Internet
A7V266E/AA MB CPU
The Ol' Asus A7V266-E?
1.The fastest Front Side Bus setting is 266MHz
2.Uses Socket 462 AMD processors
3.Uses Athlon, Athlon XP, and Duron AMD processors.
I would stick with an AMD Athlon XP. Fastest one? Hmmm, I believe that would be the AMD Athlon XP 2600+
The one that operates at 2133MHz with a FSB of 266MHz. Part number AXDA2600DKV3C
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors#Athlon_XP_.22Thoroughbred_A.2FB.22_.28Model_8.2C_130_nm.29
Here is the Motherboard Manual for your Asus A7V266-E, (It's a PDF file download. Let it download all the way before looking through it)
http://www.motherboards.org/files/manuals/1/a7v266e-100.pdf
If the above direct link does not work for you, then go here,
http://www.motherboards.org/mobot/manuals/ASUS/A7V266-E/ (Click on -> Download <- all the way to the right of -> File:a7v266e-100.pdfVersion:--Release Date:--)
Go to Page 19, Item 2. NO POWER connected to computer, make sure the SYSCLK (System Clock) DIP switches are set to 133MHz.
1, 2, 3, and 4 are set to the OFF position for 133MHz.
All you will see is the ON. The switches go to the opposite side as shown in Item 2.
I'm sure they are set there however, as your 1900+ you have in right now, uses a 266MHz FSB.
I should explain.
AMD processors are Double-Pumped. Therefore the 133MHz setting will become 266MHz for the processor. (Intel processors are Quad-Pumped.
They are both the same Core, (Thoroughbred A/B, Model 8, 130nm), so a BIOS update shouldn't be necessary.
Jul 07, 2009 | ASUS A7V266-E (A7V266-E AA/PA/WOR)...
No signal on monitor
You might try switching the VGA cable if you haven't. If that doesn't work then I'd agree with you in saying the motherboard is likely fried.
May 26, 2009 | AMD ASUS A7V8X-X MOTHERBOARD ATHLON XP...
1gb DDR 400 not recognized
That board needs to have minimally memory in pairs .. get another 1Gb stick
Dec 06, 2008 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Asrock K7S41GX "NEW" does not work :bip-bip-bip
3 beeps is a memory error. remove the memory and put it in the first slot.
also the memory replacement calls for ddr pc2700.
Robert
Sep 05, 2008 | Asrock K7S41GX Motherboard
Asus a7n8x MB and ram
i just checked & yes you can from what i was reading
Mar 30, 2008 | ASUS EN8500GT HTD DDR II, PCI Express...
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
