Question about GE GSS25VGMWW / GSS25VGMCC Side by Side Refrigerator
Help Installing Main Board on Maytag (GE) Refrigerator
I have a Maytag Refrigerator, French Door, with the freezer on the bottom, and the water dispenser inside. The model number is: MFD2561HES, and the Serial Number is 10419386GL.
The digital display inside is frozen at "0" degrees for the Freezer, and "40" degrees for the refrigerator. None of the buttons operate. A local repair shop wanted $375 for the part, plus labor to replace the main board. Google said there was a better way, and I now have a GE Main Board, Part Number WR55X10942.
The instructions are a little scary, and I am hoping you might please help me.
I can remove the old Main Board and install the new one, that is not a problem - posts here have diagrams, and I've built a few computers in my time, so the card installation looks fine.
The instructions, however, say I need to CUT the "Thermistor" wire of the J1 connector, AND cut a green wire located at the "machine compartment access panel", in a "capacitor board in the plastic housing"- where ever THAT is.
1) First off - I'm confused why a wire needs to be cut, and what in the heck a "Thermistor" is.
2) Second - I have no idea what they mean by "machine compartment access panel" - where is it? How do I find it?
3) Again, I need to cut a wire in the refrigerator interior wiring? Really? Why?
4) Some web sites I found on Google say that I need to PROGRAM MY REFRIGERATOR to tell it that there is a new card, or PROGRAM the new card so it knows what refrigerator it is installed in. Some even reference to reaching under the refrigerator for some sort of card with the "secret" information. I've found no such instruction on this site with reference to these Main Board replacement discussions. Is there something missing?
Here one site that says the Board Must be programmed:
http://www.epinions.com/msg/show_~th.../forum_id_~409
So - I guess I have a curiosity of why I'm cutting perfectly good wires, but really, I just need help verifying that I need to cut the wires, help finding the "machine compartment access cover", help finding the "capacitor board in the plastic housing", and finally I need to know if there is any programing to be done.
2 Suggested Answers
kvhappliance
  • 218 Answers
SOURCE: brought the GE WR55X10942 Refrigerator
Yes you will need to cut the wire the directions states all bottom freezer models and models with certain serial numbers... But you will not need to do other modifications specifically for bottom freezer only models.
Posted on Jul 15, 2011
I have a Maytag French Door Bottom Freezer / Refrigerator. Model MFI2568AEW. I changed the water filter today and 10 seconds after installing the new filter it started making a very loud noise like
Sounds like water hammer, has the water supply got it's own shut-off valve behind the fridge or in the basement ? Try shutting the valve then open it just a little. Perhaps the water supply was opened fully after installing the new filter.
Oct 15, 2014 | Maytag (MFI2568AEW) Bottom Freezer French...
I have an ge french door bottom freezer model gfss6kkxass. it has started collecting water under the vegtable drawers and leaking down front of freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
ll
Sep 26, 2010 | General Electric GFSS6KKXSS Stainless...
My Maytag refrigerator is freezing my fresh produce...it is a bottom freezer with in-door ice/water dispenser...how do I solve this?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 04, 2010 | Maytag MFD2560HES Bottom Freezer French...
Maytag refrigerator
IF BOTH WATER AND ICE MAKER ARE NOT WORKING YOU MAIN NEED THE MAIN BOARD. THERE IS NO FUSE.
Apr 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Malfunctioning Maytag and memory board flashing
You need a main control board and it will have to be programed but the new board comes with instructions
Mar 27, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
What is wrong with my Maytag refrigerator
You have a bad high voltage board call the manufacturer, if the unit is under 2 yrs old they may help cover the repair with the problem your having.
Jul 30, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerator
it has a bad main control board call maytag they will most likely repair it in warranty for you
Dec 09, 2007 | Maytag MFD2560HES Bottom Freezer French...
GE GSS25VGMWW / GSS25VGMCC Side by Side Refrigerator Logo
544 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Brad Goodale
