Showing "memory recall" yes 1, no 2 all times
My monitor is showing "Memory recall" press 1 for yes or 2 for no. What is this? I am getting this all times.
    Problem Solver:
  • 10 Answers
Just press yes. This will revert your monitor's configuration (screen size, panning, color temp, etc.) to an earlier state.
Posted on Dec 12, 2009
How to erase memory
If you use a Homedics BPA-110 automatic blood pressure monitor:
1 - Press the User-Select button to select User 1 or User 2.
2 - Press and hold the Date/Time Set buttons at the same time while in memory recall mode. The data for the selected user will be erased automatically.
Also, if you need a user manual, use this link to http://personalcare.manualsonline.com/ for personal care manuals.
For all other manuals, use the home page link http://www.manualsonline.com/.
Hope this helps.
Jun 01, 2015 | Health & Beauty
How do i clear the readings?
Press the User Select Button to select User 1 or 2. Then press and hold the - & + buttons at the same time, while the memory recall mode and the data for the selected user will be erased automatically.
Hope that helped answer your question.
Mar 22, 2011 | Homedics Automatic Arm Blood Pressure...
I have a problem with panasonic kx ft938 showing "fax memory full". How can i clear it?
The memory is full of received documents due to a lack of paper, or a paper jam.
Install paper or clear the jammed paper.
or, unplug the unit for about 5 minutes.
or, to clear the RAM, try one of these procedures:
(If the first one doesn't work, try the next one)
1.
Press menu 7 dial dial dial dial * 6 start
Press up-arrow key until the display reads shipment set then press start
The display will read reset counter
Select yes or no then press start
2.
Press # 7 dial dial dial dial * 6 enter
3.
Press standby set dial dial dial dial * 6 start 9 9
On success, a long beep will be heard
4.
Press menu 7 monitor monitor monitor monitor * 6 start
Parameter 65 for memory collation should be set to invalid to maximize the memory page rating
Nov 27, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
"memory recall ok?" message has started appearing on the monitor frequently
Set the "Resolution Notice" to "OFF" in the Setup Menu of your Monitor or alternatively try installing your Monitor Drivers again using the CD which came with your monitor.
Apr 21, 2009 | ViewSonic G90fb 19" CRT Monitor
Audio adjust screen pop up
I contacted ViewSonic with the same problem. They told me to turn off the monitor and unplug all the cables. Then hold the power button on the monitor for 10 seconds. Turn it back on and it should be gone.
If that doesn't work, I was told to do a memory recall on the monitor by pressing the 1 button and selecting memory recall from the list. It sets the monitor back to factory settings.
I haven't tried any of these yet but hopefully they work for someone.
Dec 20, 2008 | Computers & Internet
I have an olympus d-490 zoom every time i put the card and open the lens lcd show like T sign and yes or no, if you press yes shows card error, if you press no naothing happened
Hi
Your camera uses Smart Media memory cards, and they have been discontinued. Unfortunately there are problems with SM cards, and if I recall my Olympus symbols correctly the camera wants to format your memory card but is not able to because the card is defective.
Try another memory card if you can, Im sure you can find them used online. I think I have a pile of them but haven't bothered to test them or try to sell them as I tell people to stay away from cameras that use them.
Hopefully another card will get you running again.
Good luck from Darntoothysam com
Thomas
Sep 26, 2008 | Olympus Cameras
Problem of reset setting
Hi..there,
It's seems your bios on the monitor are the caused... Next time went it come one again...press 1 for YES. Still pop up again...you need to reset to the factory settings or need to updated your bios...
Jun 11, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
MEMORY RECALL OK? problem mine is view sonic monitor .from the past one month its showing problems in display.its giving "MEMORY RECALL OK?" and this whether i press any of the two buttons asked for ,is...
From the Users Manual for this monitor: "Memory Recall returns the adjustments back to factory settings if the display is operating in a factory Preset Timing Mode listed in the Specifications of this manual. - Exception: This control does not affect changes made with the User Color control, Language Select or Power Lock setting." When the monitor is asking "Memory Recall OK?" it either wants to initiate a settings Recall, or it's asking if the Recall was successful. In either case, the "Memory Recall OK?" message is supposed to go away when you push either button 1 or button 2. If it does this when you are adjusting settings then it's likely just doing what you told it to, even if you don't realize you told it to do that. It's also possible for one of the settings buttons to be stuck down and this is causing it to try and change the Recall settings. Push each of the buttons on the monitor and pay attention to what each one feels like as you push on it. If one of them feels different from the others, it's likely stuck. Tapping lightly on the settings buttons or on the panel beside them will usually free up a stuck button. If a button is stuck and won't loosen up by tapping beside it, you might need to pry up on the edges of the button VERY gently with the sharp tip of a pointy kitchen knife. If it's doing this when you did not touch any of the settings buttons at all, then this is likely being caused by a dendrite whisker or faulty circuit trace inside the monitor and you'll need to take the monitor to a service technician for repair. But remember to contact Viewsonic first and go to whatever Service Center that they advise, since a repair of this type may be covered under warranty. One other thing you could try before spending money on it is simply to change the Timing mode in the Windows display settings. Go to "Control Panel > Display", then select the "Settings" tab and click the "Advanced" button. Select the "Monitor" tab and change the screen timing to a different Hertz value in the "Screen refresh rate" menu box. Don't forget to save these settings by clicking "Apply" and "OK" to close all of the Windows settings windows. Hope that helps solve your problem...
Aug 03, 2007 | ViewSonic E70b 17" CRT Monitor
or you have a "crazy" micro or have a stucked push-button (or two) , first I try is change them or at least disconnect it to see what happen.
Jul 11, 2007 | ViewSonic E70b 17" CRT Monitor
Memory recall
Oct 30, 2006 | ViewSonic E70b 17" CRT Monitor
Computers & Internet Logo
42 people viewed this question
Alun Cox
David Payne
David Payne
