Question about Bose 3 2 1 GSX System
BOSE 321 GSX
ONLY THE RIGHT SPEAKER HAS SOUND HAVE CHECKED ALL CONNECTIONS CAN ANYONE GIVE ME A SUGGESTION AS WHAT TO DO
  • 1 more comment
  • JETONE Jun 07, 2008
    Lately my system has been shutting off the left speaker and only has sound through the right side. I've unhooked the power to the main unit and that seems to "re-set" the unit. It works for a while and then does it again. I'm getting tired of messing with it.........
  • gradya Aug 03, 2008
    I have same roblem right side works left doesn't I baught new acct mass ad new speaker cablebut same thing Please Help Paul
  • rtaylor1028 Oct 17, 2008
    my left speaker cuts in and out at random as well. nothing works to fix it, i have to wait for it to randomly come back on
  • 61 Answers
1st thing I would try is to connect a different speaker to right output...if it works, that eliminates speaker problem. Then swap red and white audio input cables and hook them up backwards- connect red cable to white on both ends, and white to red...cable could be bad internally. Also try hooking another source to inputs, could be blown channel.
Posted on Mar 16, 2008
Sound issues
make sure your audio out jacks are pluged into auidio in on bose and make sure it is pluged in under tv audio on the back of bose
Apr 14, 2010 | Bose 3 2 1 GSX System
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
Bose 321 only plays DVD movies in black and white
This happens because the connections are not pushed in fully. Check the connections are push them fully in, they are very stiff on Bose units.
If that doens't help, try a new cable.
Jul 07, 2009 | Bose 3 2 1 GSX System
Faint sound when watching TV with Bose GSX 321 System
I connected my surround sound to the audio output on my samsung tv and it works fine. Of course I don't have an hdmi input on my surround sound system because its an older model, but it works great. Just got to put the surround sound to audio instead of dvd or tuner setting
May 07, 2009 | Bose 3 2 1 GSX System
Bose 321 have dvd picture but no sound HDMI
check the power suply behind the acoustimass set to 115v, not to 230, that will solve you problem
Apr 12, 2009 | Bose 3 2 1 GSX System
Adding Spaekers
Are you able to add speakers to the Bose GSX 321 system?
Jan 01, 2009 | Bose 3 2 1 GSX System
Boise
yes you can.
just have your audio out from your tv going into an audio input on the bose system.
Aug 01, 2008 | Bose 3 2 1 GSX System
No sound
Well - after reading the manual - which I should have done in the first place I guess, I tried switching the power off at the wall for a minute, and after switching back on, it apparently restores the 'lines of communication' , and it worked!
Apr 05, 2008 | Bose 3 2 1 GSX System
Bac speaker bose 321
The arrays from this system are only designed to run with the Bose Acoustimass / subwoofer, which in turn will only work with the Bose DVD player. If you use them directly to an amplifier, they'll sound poor / wierd and you probably blow the drivers. You might even damage your amp.
Each speaker has 2 drivers firing in slightly different directions. The idea is (when its used with the 321 system), the inward speakers give a mix of front and centre, the outer drivers give a mix of front and rear. A normal amp won't do this....
Nov 28, 2007 | Bose 3·2·1 II System
Bose 3 2 1 GSX System Logo
160 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
