Question about Sharp AR-M160 Laser Printer
Sharp AR-M160 Maintenance light and developer replacement light have come on together. Where do I get developer from?
    New Friend:
  • 28 Answers
It's not developer light.
It is drum unit light and maintenance.
You have to replace the Drum, Blade and Developer.
After changing them you have to reset the maintenance, drum,developer counter.
This procedure must be made by a copier tech.
But if you still want only the developer the code is AR-202D
Posted on Feb 05, 2010
    New Friend:
  • 4 Answers
"#" key + Interrupt key + "C" key + Interrupt key + Main code + Start
key + Sub code + Start key :
20 + 01 = Maintenance counter clear
24 + 07 = Drum counter clear
42 + 01 = Developing counter clear
Posted on Jan 01, 2013
How is clear F2
replace toner , just test toner motor first , and test developer unit is turning , and clean developer sensor,
Aug 22, 2014 | Sharp AR-M160 Black and White Copier
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
Sharp AR-M160 A3 Printing
You need to contact Sharp ! !
They are the ones who developed the new Windows 7 drivers and now they are defective! Call them back (Sharp), and tell them they need to give you a new driver that will fix the A3 issue of your printer.
Mar 06, 2010 | Sharp Office Equipment & Supplies
My printer blanking "ch"
Check the correct instalation of the developing unit.
Jan 28, 2010 | Sharp AR-M160 Laser Printer
Where to get driver for Sharp AR-M160 for Windows 7
http://www.bioticaindia.com/ar-m160.html
Here is a link to a driver you can try. It is very possible that there is not a driver available that is compatible.
Thank you,
lee
Nov 10, 2009 | Sharp AR-M160 Laser Printer
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
Sharp AR-M165, maintenance led and developer replacement leds on
It's the drum thats causing the lines to happen. Youre going to have to get that replaced before you can reset the counters.
If you get light copies, then the developer should be replaced.
Sep 01, 2008 | Sharp AR-5316 Advanced Digital Imager...
Ch error
Some of the covers of the machine might be open.
Regards,
Cäppärs
Jul 17, 2008 | Sharp AR-M160 Laser Printer
Scanner problem
Here is a list of drivers.. Since I do NOT know your OS, this page has MANY OS options...
http://www.businessneedz.com/Sharp-AR-M160-AR-M205-Downloads.htm
Good Luck
May 30, 2008 | Sharp AR-M160 Laser Printer
Sharp AR-M160 Laser Printer Logo
1,097 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
