Question about RCA P52937 52" Rear Projection Television
No sound I was watching tv and the sound just went off. There is a little pecking sound when you use the volume control.
    President:
  • 4,402 Answers
When the unit is unplugged and replugged, it empties these registers of the corrupt data.
fix is to place a 1mfd capacitor to ground on U13101 pin (15). This
swamps the closed caption data to the micro and stops the reception of
the defective data packet. In the event that later on the resolve the
defective data problem the capacitor can be removed. the close
caption feature will not work with this cap. installed
Posted on Jan 30, 2008
I have to turn the sound up full blast when watching recorded programmes. It is fine when watching live tv so not sure if it is the tv or the Sky box, can you advise please.
Mate does your sky box have a volume control as well as your television, I have a sky box(fox-tel)with volume control as well as the television volume control.... I have the television volume up full and control the volume through my sky box(fox-tel).... Hope this helps... CHEERS...
Mar 12, 2016 | Televison & Video
Mitubishi WD65731 lost sound and I cannot control the volume on the TV or with Remote
check your cables and make sure the vol- button isnt physically stuck
Jul 13, 2015 | Mitsubishi WD65731
TV audio output vastly different for satellite feed versus DVD feed. Why?
It is possible there are separate sound level functions for the DVD player, the tv and the satellite box, try the different remotes for each by unlocking the volume control on the satellite remote until you get them close or use the device specific remote volume controls. I would also try and use HDMI if available for the DVD instead of composite. If the volume controls are different it will show on the tv, might also go through all audio settings for each device. Some devices are pre-amped or send out strong sound signals while others are line level outputs designed to be amped by the output device, in this case your tv I believe. The HDMI vs stereo audio that goes with composite may be the cause or it could be in the settings of the device. Worst case is to remember to drop volume before you switch back so you don't ruin speakers.
Jan 25, 2015 | Televison & Video
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
I have a Jensen DVD media pro 5000 hooked up to a ViewSonic TV in my Camper Trailer. Camper Trailer was purchased with DVD Player and TV in it. At night, due to child sleeping, I would like to be able to...
hi yes you can do this press AUD button near the on/off/volume control momentarily to step through the following audio adjustment options volume, bass,treble, balance (left to right) and fader (front to back). when the desired option appears in the display, rotate the volume control knob to adjust that audio feature. When no adjustments have been made for three seconds, the unit will resume normal operation. so you can fade the speakers to however you want them...hope this helps
Aug 03, 2010 | Audio Players & Recorders
Volume issue
The red/ white RCA is the most correct way for you.
Just to confirm it's analogue tv not digital you are watching?
Your friend is correct for when you watch from a settop box or pay tv provider you can run an optical cable to the bose -but- most tv's don't have an optical out.
SO- can I confirm that you can get sound out of just your tv on it's own?
I'd say that the audio outs on the back of your tv are "linked" to the tv's volume control, so you have to turn up the volume to get a louder output. Some tv's are advanced that you can disable the tv speakers, and permanentlyh set the tv output to a fixed level so you can use your surround sound (and Its volume control)
Try this one if you can.
Jan 17, 2010 | Bose 3·2·1 II System
Volume at 100% and sound too low to watch dvd tried with several dvds and volume is too low
Just cross check the volume settings in volume controls. All the sliders should be at max level specially Volume Control and CD Player.
If it is fine then there is some thing wrong with the media you are trying to watch or can be problem with audio driver.
Jul 30, 2009 | HP G70-250us Notebook
NO SOUND
Unplug the power to the tv for couple of minutes; replug and should have sound!
Jul 19, 2008 | RCA F32665 32" TV
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
Little or no sound JVC RX6010V
i had the same problem but i went to adjust settings and it says right speaker left speaker and you have to set them on ten
Jan 02, 2008 | JVC RX-6010V Receiver
RCA P52937 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
