Question about Samsung Televison & Video
Factory Settings LE32A557
Can you please give me the factory settings for the Samsung LE32A557 lcd tv?
Ready was set to yes in the service menu. It should have been no.
Posted on Dec 13, 2009
SOURCE:
How to reset a samsung 37 lcd tv to factory settings
or go into picture settings or factory reset
Sep 08, 2018 | Samsung Televison & Video
Samsung LCD TV LE40R8 - Hard Reset
How do I reset the picture on my LCD TV to the factory settings?
The P.Mode button on the remote of your LCD TV lets you cycle through four factory preset picture modes: Dynamic, Standard, Movie, and Custom. To return the picture on your TV to the original factory preset, press the P.Mode button on your remote until the TV displays the Standard mode.
Nov 14, 2007 | Televison & Video
How to reset samsung led tv to factory settings?
Step 1 Press the "Menu" button on the Samsung LED TV or the remote control. Step 2
Press the up or down arrow buttons and highlight "Support." Press the "Enter" button to open the Support Menu.
Related Reading: How to Reset a Samsung DVD Recorder Step 3
Select "Self Diagnosis" and press the "Enter" button. Select the "Reset" option and press "Enter." Step 4
Enter your TV's security PIN. The default PIN is 0000; however, if you had previously changed it, enter the new PIN. Step 5
Select "Yes" to confirm your selection when the "All settings will return to factory defaults except network settings" dialog message appears on the screen. The TV powers off automatically and restores the default factory settings.
How to Reset Samsung LED TV to Factory Defaults
Nov 29, 2015 | Samsung Televison & Video
There is a Video problem with my Samsung LCD. The sound is clear but Colour Balance Setting is disturb. The Colour is mixing with each other. Can You tell me the procedure for My TV Setting?
Before you set up try a reset
Resetting The Picture And Sound To The Factory Settings
as far as advanced settings are concerned, set the contrast backlight and brightness so you can see the best blacks without it looking too milky, the best whites so you can discern the whites and they aren't clipped, then look at colour balance if it looks wrong when you turn the colour off.
it shouldn't be very far out in factory settings. Operation How To Change The Picture Settings On Your LCD TV LCD TV...
May 12, 2014 | Samsung LN-S2651D 26 in. LCD Television
Hi i did rest factory after changing the tuner type, after a while just a samsung log comes and goes. i;m terribly devastated any solution please
There was no need to make a factory reset after replacing the tuner, provided the replaced one is with its original part number. As far as you did a factory reset, all data might have reset to its original factory settings. The only thing to do is to update its firmware. You haven't provided the brand name and model number to your TV here. So I cant give you more details. Just check this, and see whether it help you.
Jan 08, 2013 | Televison & Video
Sound no picture
I think you hit the wrong button before....
To restore the settings please try to restore factory setting and see what happen..
Nov 22, 2011 | Samsung LN22A450 22 in. LCD HDTV
Samsung Le40a556 factory reset
with tv in standby press INFO / MENU / MUTE / STANDBY on remote the tv will come on in factory menu settings look for reset use DOWN NAV KEY until highlighted and press RIGHT NAV KEY
to exit settings press standby the tv will come on and follow on screen instructions
DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK IF CHANGED
Dec 13, 2009 | Televison & Video
Factory reset Menu
IF A SAMSUNG TV Put tv into STANDBY
WARNING DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK
Press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu displayed and FACTORY RESET (12) is on it
ONLY USE DOWN NAVAGATION KEY until you highlight factory reset
NOW PRESS RIGHT NAVIGATION this will reset all settings
PRESS POWER ON THE TV TO EXIT then turn on tv and retune
Nov 07, 2009 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
I want to restart my samsung LCD TV LE32R71B, how can i do it?
You can reset 2 ways Put tv into analog mode by pressing TV/DTV on remote then press Menu move down to the satellite pic press enter you will see plug & play in the list press enter and follow on screen instructions
The other way
WARNING TV WILL NOT WORK IF YOU CHANGE ANY OTHER SETTINGS
With tv in STANDBY Press INFO / MENU / MUTE / STANDBY on remote the tv will come on with the factory settings displayed
FACTORY RESET ( 12 ) will be in there USE DOWN KEY ONLY until Factory reset is Highlighted then press the RIGHT KEY the set will reset all settings PRESS POWER ON TV TO EXIT
Turn ON TV AND RETUNE
Nov 05, 2009 | Samsung LE32R71B 32 in. HD-Ready LCD...
How do i reset factory sttings on samsung lcd tv
go into analogue tv press menu move down to settings you should be able to enter plug and play in menu press ok( if you can not enter it you are not in analogue )
if not solve problem try this !! warning !!
you will enter the service menu DONT ENTER OR CHANGE ANY OTHER ITEMS THAT ARE DISPLAYED AS TV WILL NOT WORK IF YOU DO
With tv in standby press INFO / MENU / MUTE / STANDBY on remote
then use ONLY DOWN nav-key move to number 12 FACTORY RESET
press RIGHT nav-key will reset all tv settings to factory ones
PRESS STANDBY TO EXIT on remote
you will have to RETUNE after tv after
Oct 25, 2009 | Samsung LN46B530 LCD TV
Open Questions:
Televison & Video Logo
339 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
