Question about Nokia 3110 Cellular Phone
Nokia 3110 classic.on the time of update software USB Data cable have been disconnected. and that time mobile was automatically off And after its not starts. Please solve my problem.
How to update the nokia 6120c?
There is a software named "Nokia Software Updater" just download this to your pc then connects your mobile to your pc via data cable (USB cable) and select PC suit option then open the updater and follow the instructions to update your mobile
Dec 08, 2011 | Nokia 6120 classic Cellular Phone
How to flash my nokia 3110 classic mobile
Hi..............
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit) To back up your files *Install the Nokia PC suit *open Nokia PC suit >Select Back up
To restore Backed up data *Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset *A Computer *Nokia PC suite of your handset *Internet connection(Min speed 1Mbps) *Nokia software updater(you can download by using Nokia PC suit)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
Flash resets security code to 12345
Thank you have a nice day...:)
Feb 12, 2011 | Nokia 3110 Cellular Phone
Can i install software in my nokia 3110 classic cell phone ? if yes then how?
Hi....
To flash(format) you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash(format) *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
For more inf about formatting read my tips and how to do.......
Thank you
Feb 03, 2011 | Nokia 3110 Cellular Phone
Reformat in hand 3110c
Formating the mobile phones is known as flash
To flash your Nokia 3110c you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
Thank you Don't forget to rate
Jan 28, 2011 | Nokia 3110 Cellular Phone
3110 CLASSIC MUSIC PLAYER NOT OPEN PLS REPLY SIR THEMES IS CRUPTED OPEN MOBILE ERROR
you need to update your phone software as soon as possible . to update it yourself :
1) you need to have high speed internet.
2)data cable
3)nokia software updater.
if you have all these just start nokia software updater while your phone is connected and your pc is connected to internet. the phone will restart itself several times while updating . wait for 1 hour and your phone will be updated and everything will work fine.
to download nokia software updater go to http://www.nokia.co.in/support/download-software/device-software-update
if you dont have any of these ..... simply go to nearest nokia care and get it updated.
if you dont have
Dec 18, 2010 | Nokia 3110 Cellular Phone
I WANT UPDATE MY NOKIA 3110 Mobile software
I WANT UPDATE MY NOKIA 3110 Mobile... Answer Failed: retry 07.21 for Nokia 3110 Classic * HOW I Install & Get Software My Mobile Phone mp; Get Software My Mobile Phone
Jul 01, 2010 | Nokia 3110 Cellular Phone
Cannot power up a nokia 3110 classic. full charged battery
nokia 3110 classic.on the time of update software USB Data cable have been disconnected. and that time mobile was automatically off And after its not starts.
Oct 03, 2009 | Nokia 3110 Cellular Phone
Automatic restarting problem with Nokia 3110c mobile phone
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 - Memory Cards - Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Feb 12, 2009 | Nokia 3110 Cellular Phone
Install antivirus Mobile Nokia 3110 Classic
i don't think that this phone supports softwares or third party softwares for installation.. it come with pre installed software....
if you are able to install softwares you can install any one .... F secure is a good one
Jan 03, 2009 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
167 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
