Question about Canon iR 2016i Black and White Copier
Eroor e808 & e001 - Canon iR 2016i Black and White Copier
  • Canon Master
  • 1,297 Answers
Clean the fuser components,thermistor,thermofuses,heater lamp and the rollers,and reset the malfunction open and closed the front door.
Posted on Dec 12, 2009
My machin giving error e001 and error e808 and not working properly
make a scan with an updated antivirus and chek windows update
Sep 22, 2013 | Computers & Internet
ERROAR E001 AND E808
u can clear E001 in the service mode Press * 28 * go to clear press OK then err press OK . and the E808 is the cooling fan malfunction .it can be because of the erratic power fluctuations or damaged fan.
and the if E001 happens during copying then u have to check the fusing unit as sometimes the pressure roller bush gets misplaced from original position causing jam and code
Aug 03, 2011 | Canon iR 2016i Black and White Copier
I have an System ERROR E001 following Error E808 on my canon 2016j copier and waht shal i do me out guys
E001 0000 Abnormally high temperature (detected by main thermistor)
The main thermistor detected an
abnormally high temperature (240 deg
C) during temperature control.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the DC controller PCB.
E001 0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E808 0000 Fixing drive circuit failure
- The heater does not turn on.
- A fixing drive motor failure was
detected.
- Replace the fixing drive motor.
- Replace the power supply PCB.
Feb 19, 2011 | Canon iR 2016i Black and White Copier
I changed the drum of my client's canon 2016j recently. it was worn out (with cut on the edge).he now is reporting that after every 15/30 copies the machine brings error code 007.once he restarts the error...
the error E007 means fixing trouble.
The fixing foil is worn out or damaged.You need to change the fixing foil.
These isnt related to power.If the power is involved You can have messages like E001, E002, E808, because printer doesnt gets enough power to heat up or rotate fixing unit.
Also if You want to prevent power issues you can place power stabilizer before copiers power supply.
For service manual You can contact me on emma.servis@gmail.com
Hope that helps!
Sep 06, 2010 | Office Equipment & Supplies
Error 001, error 808
the e001 code is something is going with the fixing assembly. one of the thermistors could be going bad.
E808 is a Zero Cross error. We most commonly see power supplies or bad wall voltage cause this code.
The following information is coppied from the IR2016 Service Manual.
E808-0000 DRIVE CIRCUIT FAILURE
A zero crossing signal cannot be detected.
A fixing drive motor failure has been detected.
  • The heater does not turn on.
  • A fixing drive motor failure was detected.
  • Check the connector of the fixing film unit.
  • Replace the fixing film unit.
  • Replace the fixing drive motor.
  • Replace the DC controller PCB.
  • Replace the power supply PCB.
M201 - Fixing Drive Motor - FK2-1067 - J202 on the DC controller PCB - E007, E808
Power Supply - FK2-1074
Jun 14, 2010 | Canon iR 2016i Black and White Copier
I want user manual of Canon ir2116J copier
conon IR2116J printer E001 and E808.Please help me.
Oct 27, 2009 | Canon imageRUNNER 2000 Copier
Download standby error
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание E000 0000 Fixing temperature abnormal rise E001 0000 Fixing unit temperature rise detection (by main thermistor) 0001 Fixing unit temperature rise detection (by sub thermistor) E002 0000 Fixing unit temperature insufficient rise E003 0000 Low fixing temperature detection after standby (by main thermistor) 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 Fixing film rotation error E010 0000 Main motor rotation error E019 0001 Waste toner full detection 0002 Waster toner full detection sensor failure E052 0000 Duplex unit connection error E100 0000 BD cycle out of range E197 0000 Erroneous communication with printer engine E500 0001 Finisher communication error E520 0000 Offset error E531 0000 Stapling error E540 0001 Paper surface not detected (standard tray) 0002 Not moved within the specified time (standard tray) 0003 Sensor not reached within 3 seconds (standard tray) 0005 Encoder clock failure (standard tray) E542 0001 Paper surface not detected (optional tray) 0002 Not moved within the specified time (optional tray) 0003 Sensor not reached within 3 seconds (optional tray) 0005 Encoder clock failure (optional tray) E575 0000 Stack delivery error E584 0000 Shutter failure E716 0000 Erroneous communication with optional cassette E719 0000 Erroneous communication with card reader (serial communication) 0002 Erroneous communication with coin vender (serial communication) E733 0000 Erroneous communication between controller and printer E736 0000 CCU communication error E739 0000 Erroneous communication between controller and network board E744 0001 Language file/boot ROM/USB memory error 0002 0003 0004 E805 0000 Fan failure E808 0000 Fixing drive circuit failure
Apr 10, 2009 | Office Equipment & Supplies
System error E808
0002
0003
0004
Mar 22, 2009 | Canon CLC 1140 Copier
CANON IR2016
hi... try to clean up your copier... usually dust accumulates inside the copier that's why paper inserted will always jam....always see to it that you copier is free from dust and other small particles that would cause your machine to get errors....
Feb 27, 2008 | Canon PC-940 Black and White Copier
Canon iR 2016i Black and White Copier Logo
196 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
