Question about Samsung SpinPoint M80 HM080HC 80 GB ATA-100 Hard Drive
My SAMSUNG HM080HC USB Device cannot detect or pop-up in "my computer" in device manage> disk drive.. is detected SAMSUNG HM080HC USB Device
    Sergeant:
    Champion:
  • 232 Answers
In disk manager, right click the disk and change the drive letter. Hopefully it will pop up.
Posted on Dec 12, 2009
External hard drive not seen in my computer, disk manager and device manager
Can you see the lights or hear spinning. Try using the hd on a diff system also use a different USB cables.
You could also open up Device Manager -> click on View -> select Show hidden devices -> expand all the nodes by clicking on "+" symbol and if you find any greyed ones right click on them and select Uninstall -> restart the computer and try to connect your drive again.
Jul 16, 2015 | Sony 500gb External Hard Disk Drive, Usb...
What can i do? my jetFlash V85 is unknown
Connect your flash drive to your computer using an available USB port.
If your flash drive is not recognized, you'll usually receive an error that says "USB Device Not Recognized."
Click "Start" > "Control Panel" and open the system configuration by double clicking the "System" icon.
Navigate to the "Hardware" tab and click the "Device Manager" button to open the Device Manager.
Click the "+" next to "Disk Drives" and locate your USB flash drive.
A question mark icon should be shown to the left of the label.
Right-click the device name and select "Uninstall."
Open the "Action" menu at the top of the Device Manager and select "Scan for hardware changes."
This will scan your PC for any new devices.
Because you uninstalled the flash drive, it will be detected as a new device and the drivers will be reinstalled.
Click "Start" > "My Computer" and look for your flash drive.
If this process was successful, your flash drive should now show up under My Computer as a storage disk.
If its listed as an unknown device
Then right click on your flash drive select rename
Hope this helps
Nov 08, 2012 | Electronics - Others
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
Hp dc7100sff cant detect usb drives except printer
hello,
For this you sholud go to in xp my computer ->right click ->manage->device manager->usb ->right click and give to all update driver this is valid also for win 7
Sep 24, 2012 | HP Compaq dc7100 PC Desktop
Hi my toshiba mk3265gsx hard disk is detect as a usb device as external, but not work and has no partition no bad disk and can not be able to work with this, it is just a usb device with no action (this...
With a brand new drive, you have to initiate your drive using the Disk Management tool in Windows.
To do this, go to Start-->Control Panel --> Administrative Tools --> Computer Management. Then select Disk Management from the menu on the left. Once everything is loaded up, you should see your new drive in the list of volumes on your computer. You'll have to right click on it and click Initialize Disk. Once you've initialized it, you'll have to formate the drive and create partitions.
If you need anymore help, let me know.
Mar 25, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
External HD is not detected by laptop Windows XP
A common issue...I'm sure your hard drive is working fine, Windows is just not giving it an unused drive letter.
1. Insert the device (camera or usb drive)
2. Right-click "My Computer" and select "Manage".
3. Click on "Disk Management"
4. Right-click the item in the list that looks like your camera or usb drive, and then click "Change Drive Letter and Paths."
5. Click "Change".
6. Give it a drive letter that is not being used.
7. Click OK.
The device should work instantly after that.
Feb 09, 2010 | Western Digital Scorpio WD1600BEVS 160 GB...
System is not detecting
To determine if your system is detecting the USB drive or not
Windows XP Right click "My Computer" >> Properties >> Hardware Tab >> Device Manager
Windows Vista/7 Right click "Computer" >> Properties >> Device Manager
If your USB drive is not detected at all either the drive is bad or the usb port is bad, I would try another USB port to rule out the issue being a port
If you see a ? or ! then your operating system had trouble installing a driver for it uninstalling and reinstalling the driver should resolve the issue
Please comment if you need further assistance or clarification
Thanks
If
Nov 21, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Detect
Hii
Certain times its does happen on windows operating system. Kindly follow the steps below this wud surely help u out.
Try checking the "disk management"
to go there:
right click "my computer"
click "manage"
now theres a new window that popped up, click the "disk management"
you should see your removable disk there, once u see ur ext hard disk, right click and assign a drive letter, your problem will surely be solved.
@ CHINA Mobile
Try This
Goto > MY COMPUTER > Right click PROPERTIES > HARDWARE tab > DEVICE MANAGER
Here you will be able to see ur china mobile's port with a Yellow Question mark icon > Right Click and Update Drivers.
NOTE: You may or may not find drivers for such phones, plz also check if ur mobile phone has a option using ur cell phone as USB Data Manager.
Hope it helps.
Regards
Sep 06, 2009 | Computers & Internet
HDD enclosure does not work
For that you need to uninstall all usb driver from device manager.
Right click on my computer icon then you see system property then go to hardware -> device manager then uninstall usb drivers 1 by 1 .
Then restart computer then all usb drivers are automatically installed.
Then connect your harddrive if still face same problem then connect your harddrive to another computer then check.
If another computer cant see your harddisk then your harddisk has hardware issue.
It need repairing .
If it is in warrenty take it to service shop they replaced it.
Aug 01, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Samsung SpinPoint M80 HM080HC 80 GB ATA-100 Hard Drive Logo
524 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
ismael castillo
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
