Question about Kenmore 73952 Gas Dryer
Kenmore 73952, If I held start switch, dryer running, but not running if switch not held down. And no heat out when motor running
    President:
  • 1,891 Answers
The motor sw ( a part of the motor) has stuck and is not working . it is a centrifical sw. / you may may correct it by cleaning out the motor . ( like blow it out with hi pressure air . if this does not work the motor will have to be replacedl .. mm
Posted on Dec 12, 2009
Kenmore Elite Model # 110 60982990 Dryer only Runs when Start Button is held down AND does not heat
The switch on the motor is broken needs replacement call for service
I’m happy to help further over the phone at https://www.6ya.com/expert/george_106a9535a98aec8a
Jan 02, 2018 | Kenmore Dryers
My electric dryer starts then shuts down after 5 seconds
Centrifugal start switch, built into motor, may not be releasing when motor comes up to speed. A little light oil on sliding part of switch might help.
Dec 13, 2013 | Kenmore 73952 Gas Dryer
Kenmore Elite Gas Dryer starts/runs/drys only w PTS held on?
push to start button needs replacing,sometimes you can jump that out if you have another switch that starts the dryer when you close the door
Jan 15, 2013 | Kenmore 73952 Gas Dryer
Start button will not stay on. dryer works if it is held in
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
b
Sep 28, 2010 | Kenmore 73952 Gas Dryer
Kenmore Elite 73942 Gas Dryer only runs with start button held
Unplug the dryer. Open the control console.Mark and remove the wires from the start switch.
Using a volt meter set for continuity,touch meter leads to R1 and R2 while pushing the switch. No reading is a bad switch.
Touch meter leads to R2 and CT1. No reading is a bad switch.
If the switch checks out good the start windings in the motor are bad.
Dec 27, 2009 | Kenmore 73952 Gas Dryer
Kenmore-110.73952101 start button won't work unless its held down
It sounds like you need a start switch located on the motor To replace this you will need to get the 2 screws off where the harness plugs into the motor MAKE SURE THE POWER IS OFF :) Ask you locat parts placeGood luck:)
May 05, 2009 | Kenmore 73952 Gas Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
When the start button is pressed and held down the dryer will run but when the button is not being held dowm the dryer cuts off. What could that be? It is a Kenmore 90 Plus Series Even Heat Dryer
i would say that it is in the "lockup" circuit in your motor. there is a centifugal switch which moves when it senses RPM of the motor which then in turn closes a set of contacts within the motor housing, thus locking the run contacts to keep your motor running. odds are that the switch, (which moves along the motor shaft) is dry or blocked by debris (lint) that gets caught in the motor housing.
a good cleaning and then a shot of lube on the shaft usuallly solves this problem....
good luck; jay
Mar 21, 2009 | Kenmore 62622 Electric Dryer
Kenmore gas dryer 73956
sounds like motor switch
Feb 09, 2009 | Kenmore 73952 Gas Dryer
KENMORE DRYER MODEL# 110.85091400
could be problem with motor relay next to pcb..try switching the relays 1 is for heat and the 1 with blue wires is motor if runs ok replace relay if still have problem ck door switch operation
Jul 31, 2008 | Kenmore 73952 Gas Dryer
Kenmore 73952 Gas Dryer Logo
88 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
