I get the error code when I run the PSA on my DELL studio 1555 of "2000-0146". I remove the CD and run again. Same error, what do I do?
  • 1 more comment
  • idayala2000 Dec 12, 2009
    I finally got win7 loaded back on the laptop. I attempted to run the diagnostics again and I still get the same error. How do I clear the log so I can run the test again and verify if I have a hard disk issue or not?
    I still get the same error code when I run the tests. But I got win7 back and loaded. How do clear the logs and test the drive again to verify if there is a issue or not?
  • idayala2000 Dec 13, 2009
    After I got help from FixYa. I contacted Dell support and in little to no time they agreed it was a hard drive issue and are sending me a replacement.
  • 10,515 Answers
There is a Complete Description of this Problem in Dell Technical Forum. Read :-
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=126A722713F6D0D0E0401E0A55174AE6&journalid=7A722E69900DBE11E040AE0AB6E10FB2&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=&toggle=&dl=
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 12, 2009
  • taran_2005
    taran_2005 Dec 12, 2009
    OK!!
    If this Code is Still there, it sounds as you need to replace the Hard Drive. On Most Occasions, this is a Hard Drive Error Code.The error code itself means the electronics in the hard drive itself are failing.You can try a few things. When you boot into XP, double click on "My Computer", and then RIGHT CLICK on Drive C:. There is a tab called tools. Start by running a Scan-disk on the drive. It will require you to reboot your machine. Then when scan-disk is done, run a De-fragment on the drive. Run your DST again and see if you still get the error. If so, may I suggest starting to back up all your needed data and important stuff, cause the drive could fail. I have talked to some owners who's drive lasted another month, and some where they just died the next day. Better to be safe than sorry!
    Hope i helped you.
What does error code 1000-0147 mean?
Pre-Boot System Assessment (PSA) Diagnostics and Error Codes For Dell Computers - KB Article - 300428
http://support.dell.com/support/top...2000-0148 = IDE error
How to Fix:
Remove and reinstall the CD/DVD Drive for the error codes:
* 1000-0147
* 2000-0147
* 1000-0148
* 2000-0148
* 2000-0149
Please see the Service manual for instructions on how to remove and replace the CD/DVD Drive. Be sure to remove and reinstall the cables for the CD/DVD Drive if you are on a Desktop Computer.
This is a Dell ONLY error code.
To find the Service manual for your model, simply search the web using:
(name and model of Dell computer) manuals
May 16, 2014 | Dell Inspiron Computers & Internet
I have a dell inspiron E1405 laptop. when i am not using it for half an hour after opening it it is going into the following error: error code: 0148 message error code: 2000-0148 message unit:...
Go to
http://support.dell.com/support/0148
For further support as you have a hard drive error.
Hope this helps.
How to run PSA Diagnostics
Article Summary: Instructions on how to run the PSA Diagnostics, and an Error Code list with possible solutions. Table of Contents:
  1. Start the PSA Diagnostics
  2. Error Code List
Step 1: Start the PSA Diagnostics
  1. Restart the system.
  2. At the Dell logo screen, press <F12>.
  3. new_note.jpg Note: Some systems do not have an F12 key, to access the boot options you have to press the <0> (zero) key at the Dell logo screen.
  4. At the One Time Boot menu, press the <Down> arrow key to highlight Diagnostics, then press <Enter> to begin PSA.
  5. Write down any error codes listed.
  6. Use the list provided in the next section to see what the error code means.
Feb 16, 2011 | Computers & Internet
While running diagnostics am getting an error code 2000- 0111 in my inspiron 15R laptop
If you receive an error during PSA Diagnostics, look below for the associating error code. If the Error
Error Code
Error Message
Link to Possible Fix
PSA 1000-0111
PSA+ 2000-0111
(Name of Exception) exception occurred at selector XXh offset XXh.
Contact Dell
Jan 04, 2011 | Dell Inspiron 1525 Notebook
Inspiron 1100 wont boot up,screen stays black,i can hear the fan running,sounds like hd is starting
STEP: Run the Preboot System Assessment (PSA)
Additional Information
  1. Ensure that the computer is powered off.
  2. Press and hold <Fn> and press the power button to power the computer on.
  3. Release both buttons. The PSA diagnostics sequence begins.
  4. Make note of any PSA beep codes or PSA error codes
Check for PSA Error codes on support.dell.com.
If all Test Passed. Then Perform Dell Factory restore or OSRI.
Jan 20, 2010 | Dell Inspiron 1100 Notebook
The laptop screen is almost blank/black. an external monitor is working ok. when i close the lid of the laptop and open it again the screen comes on for a sec but then goes off again almost blank/black....
As per Dell Technical support LCD kit needs to be Replaced.
I Would recommend to
Run PSA Diagnostics. Check for PSA Error codes
if unable see display during PSA Diagnostics use External monitor to make note of Error code.
Check Error code on support.dell.com
If no Error codes. Then Only option is replace LCD kit
Jan 19, 2010 | Dell Latitude D430 Notebook
Starting problem, sometimes automatically restarts or shutdown
Jan 16, 2010 | Dell OptiPlex GX280 PC Desktop
Studio 15 screen blank
there is an inbuilt hardware diagnostic..
turn the computer off then hold Fn + power button to turn it back on.. it will automatically initiate PSA diagnostics.. will beep and ask you if u see the colour bar displayed.. if u see them respond accordingly or else.. let it run.. within 10 minutes you'll get an error if its hardware glitch.. call dell tech support at 1800-624-9896 and tell the error code.. they will replace the lcd kit by sending a tech at your place.
Dec 19, 2009 | Dell Studio 15 Laptop
Sudio 17 spontaneously shuts off
Troubleshooting With PSA Diagnostics on a Laptop Computer
  5. check PSA error code on support.dell.com
Dec 09, 2009 | Dell Studio 17 Notebook
Cannot read disk
"A disk read error occured press Ctrl+Alt+del to restart " FOLLOW THE BELOW INSTRUCTIONS TO RUN DELL DIAGNOSTIC ON INTERNAL HDD Open the Dell Diagnostics on either your hard drive (F12) or from the Resource (Drivers and Utilities) CD. Running from the hard drive is the preferred method of using the diagnostics. If problems occur when running from the hard drive or there is no Utility Partition, the diagnostics can be run from Resource (Drivers and Utility) CD. From your hard drive: Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. When the boot device list appears, highlight ?Boot to Utility Partition? on desktop systems or ?Diagnostics? on portable systems and press . Note: On portable systems, PSA will be executed first. When PSA completes, press any key to load the Dell Diagnostics.? Go to step 2. NOTE: If you receive a message stating that no Diagnostics utility partition has been found, follow the instructions on the screen to run the Dell Diagnostics from your Resource (Drivers and Utilities) CD. From the Drivers and Utilities CD ResourceCD: Insert the Drivers and Utilities CD into the CD drive. Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. NOTE: This feature changes the boot sequence for one time only. On the next start-up, the computer boots according to the devices specified in the system setup program. When the boot device list appears, highlight IDE CD-ROM and press . Select Boot from CD-ROM option from the CD boot menu. Select Run the 32 Bit Dell Diagnostics numbered list. If multiple versions are listed, select the version appropriate for your platform. Go to Step 2. After the Dell Diagnostics loads, the Main Menu appears. Click the button of the option you want. If a problem is encountered during a test, a message will display the error code and a description of the problem. Write down the error code and problem description and follow the instructions on the screen. If you can not resolve the error condition, contact Dell. If you run a test from the Custom Test or Symptom Tree option, click the tabs above the right window for more information: When the tests are completed, if you are running the Dell Diagnostics from the Drivers and Utilities CD, remove the Drivers and Utilities CD. Close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and restart the computer, close the Main Menu screen. Regards Sunil Dsouza
Dec 04, 2009 | Dell Dimension 2400 PC Desktop
Dell Inspiron 6400 shuts off at randomly
Nov 21, 2009 | Dell Inspiron 6400 Notebook
23 people viewed this question
k24674
jasbo
jasbo
