Question about Maytag Washing Machines
How the belt goes on the mde9206ayw to make it snug
    Brigadier General:
  • 5,158 Answers
Here is the service manual for your dryer. i believe the section you want is
6-3
http://www.servicematters.com/maytag_library/docs/16023086.pdf
Posted on Dec 12, 2009
SOURCE:
Changing belt on Maytag electric dryer model #MDE9206AYW
Go to www.repairclinic.com and enter MDE9206AYW. You will be presented with a list of common parts and may be able to view a video showing disassembly.
Jul 29, 2016 | Maytag Dryers
I have a 2003 dodge stratus rt 2 dr cpe 6 cyl. My belt that goes to the alternator needs to be tightened. How do you do that?
it has an automatic tensioner . perhaps you need a new BELT they do stretch just before breaking usually
Nov 23, 2015 | Dodge Cars & Trucks
How to remove top and front panel on Maytag Dryer model MDE9206AYW
To access these parts you first need to first lift the top up. This is done by pressing the clips inward. These are located on the left and right side in between the top and front on the dryer. When this is done the top will left up and backwards. Next, on the upper inside there are two screws, usually 5/16" bolts, that will need to removed to take the front off. Now you'll will access to the inside of the dryer. The belt will have to be removed to to take the drum out to test the rollers.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 06, 2012 | Maytag Dryers
Mde9206ayw won't heat
Check your heating element. If it's not broken (the coils), then you have either a bad thermal cut-off, fuse or thermostat.
May 06, 2012 | Maytag Dryers
Maytag MDE9206AYW will not heat. What do I need
I assume it is a gas dryer. Turn it on and if no clicking sound is heard within 30 seconds the spark ignitor needs a replacement. If it is an electric dryer you need to check the relay for the burner system first
Apr 16, 2010 | Maytag MDE9206 Dryer
Dryer making noise when turned on
you have to specify what make your dryer is to be able to answer question
Feb 06, 2010 | Dryers
Just need to now how the drive belt goes. My belt
I don't have a diagram but it shouldn't be to hard. You will have to drop the deck. Then when installing the new belt remember to always place the inside of the belt (V) into the pulleys and the outside of the belt (flat side) up against the larger idler pulley. When you have the belt on properly it should be snug. If you have excessive play you need to try a different routing2.gif around the idler.
Good luck and let me know if this helps.
Thanks
roundo4
Sep 07, 2009 | Cub Cadet Street Sign- tractor lawn riding...
The belt broke on my Whirlpool super capacity dryer (23 years old)model number LG7686XPO. we are able to get the belt could you plase send us a diagram of how the belt goes on? and some directions...my...
Your belt will use one of these configurations. Just right click on the picture, copy & paste it into a document or save as and them open it with a photo viewer.
Jun 30, 2009 | Dryers
How to change belt on maytag model MDE9206AYW dryer
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
May 02, 2009 | Maytag MDE9206 Dryer
Washing Machines Logo
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
