Question about Acer (KV.16X04.007) DVD Drive
I have a hp pavillion laptop with the philips dvd-ram sdvd8821
I have a hp pavillion laptop with the philips dvd drive in it, device manager detects the dvd reader and says it is running with no problems. i can hear the drive read the cd when inserted, tho when trying to access the drive through my computer the window hangs at the hourglass for a min or so, then says please insert a cd.
  • 832 Answers
Just try to reinstall the DVD driver software through the Add Hardware wizard at the control panel. From the Start menu, left click the Control Panel, and the Add Hardware. Right to left click to open. Just follow the instructions and let your PC do the rest. If you have an internet, connect your PC without opening any window. Your PC will autoconnect and search the internet for the proper software driver. Wait for
a few minutes, until it is installed. Hope this Help.
Posted on Dec 12, 2009
  • Walt May 23, 2014
    Likely a bad DVD drive. Have you tried playing a music cd or reading a non-dvd disc? Might try cleaning the laser.
I hav a hp pavillion dv4 laptop.. recently i downgraded my OS from windows 7 to windows xp... and eversince then .. im being faced by lots of problems.. one of them is the DVD drive problem... it reads...
you might have to physically unplug the cd/dvd drive restart your computer this should activate the found new hardware wizard
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jun 06, 2011 | HP 419320-001 - HP Pavilion dv4000 Series...
Unlock the region on HP Pavillion dv6-2111TcX with bluray
Go to control panel /system / hardware tab , then click on device manager then find your dvd/cd drive right click on that and select properties. there should be several tabs the one you want will be named dvd region or something like that.
some drives will only let you change the region a couple of times
Jul 25, 2010 | HP Computers & Internet
The dvd/cdrom drive on my pavillion laptop is not
go to start -> run here in the run box write devmgmt.msc This will lead to device manager here in disk drives or sata-ata remove ur cdrom driver by right clicking it and choose uninstall. This will uninstall the drivers for cdrom and now at the top where ur computer name displayed right click on it and select scan for hardware changes. It will automatically install drivers for it.
May 06, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Hello i'm having HP PAVILLION DV6000 and OS is
You first remove that device from device manager.
Then restart the pc.
You may check the BIOS menu for that device for any clarification.
After restart since u have removed it the OS will detect the device and install it automatically.
Hope this helped.
Jan 09, 2010 | Pioneer DVR-107D DVD±RW Burner
HP pavillion DV6500 CD/DVD RW not responding, unit will try to boot up many times when system is starting but when I put in a CD or DVD no response and doesn't show a drive in My Computer. I've opened up...
Turn off the Notebook remve all the peripherials, Remove battery and disconnect AC Adapter and then press and hold down power button for thirty seconds.
After 30 Seconds connect Battery and Power supply as soon as you tun on the Notebook keep on hitting F10 Notebook will show BIOS then F9 Notebook will show Load Set-up Default than Hit yes and Hit F10 again it will show save Exit and chnages now that show Fix the Problem
If not than use Philip Screw Driver take out optical drive and put it back in Reinstall CD/DVD Drive drivers using Device Manager .
Thanks and Regards
Neeraj Sharma
HP and Compaq Notebooks Expert
Oct 08, 2009 | HP Pavilion dv6000z Notebook
HP Pavillion WebCam Unknown Device (Not Working) plz help !!
sounds like that particular webcam isn't compatible with vista.
Jul 16, 2009 | HP Pavilion dv6000z Notebook
Hp pavillion dv9000- cd/dvd rw drive not working
you have to send it back to hp to get it fixed, this is the second time mine had the same problem
May 10, 2009 | HP Pavillion DV9060US Notebook
HP Pavillion not reading audio CD
It is possible that this is a drive issue, I've seen drives that one of the optical reader device has gone out, but generally it'e the DVD reader and will only read CD's. It's very rare that the CD reader goes and the DVD reader works. Before you replace drive, if it's only music CD's (you didn't mention program CD's), then update your media player. If it still won't play, then unistall the media player and completely reload it. At this point you can replacse the drive.
Jun 28, 2008 | Computers & Internet
Acer aspire 5102 with philips sdvd8821 dvdram drive
alright. bubul78, your post is in no way shape or form a solution for the problems given by other users. I too have a acer laptop with the philips dvd drive in it, device manager detects the dvd reader and says it is running with no problems. i can hear the drive read the cd when inserted, tho when trying to access the drive through my computer the window hangs at the hourglass for a min or so, then says please insert a cd. only solution is that something is physically wrong with the drive. ok so solution found, replace the cd drive. but where is acers sight to order replacement parts? poor site navigation in my opinion.
Nov 01, 2007 | Acer (KV.16X04.007) DVD Drive
Acer (KV.16X04.007) DVD Drive Logo
308 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
