Question about Samsung HLR5667W 56" Rear Projection HDTV
Green Screen I have had this set for less than 2 years and now there is a green screen. How can I fix this. The TV wasn't cheap either.
  • ThePope78 Jan 25, 2008
    i also have the issue with the picture randomly turning green off and on...if you turn the unit off, then back on, it works fine...sometimes it works, sometimes its still there and needs turned off and on again...
  • lampshade26 May 26, 2008
    i have a green screen i need to know where the dvi board is in the tv so i can check the connection
    Problem Solver:
  • 7 Answers
If set displays intermittent green outlines around images, check DVI cable attached to DMD board from digital board. Poor connections on the DVI jack on the DMD board can cause the intermittent symptom. Pull up slightly on the body of the DVI cable connector and check video. Replace DMD board as necessary.
Posted on Feb 24, 2008
LG 50PK550 Plasma Single Thin Green Vertical Line
It is going to be one of two basic issues:
1. There is a poor connection somewhere in the set--either with a plug or cable or on one of the boards.
2. There is a board that is beginning to fail causing this.
Either would require a shop and may or may not be worth the cause.
Having seen hundreds of these sets all are more prone to flaky problems than the older sets and average life span is 3-5 years.
Shop I work for 80% of them are 2 years old or less.
If problem began shortly after set was moved or relocated I would lean towards a bad connection somewhere.
Mar 17, 2012 | LG 50PK550 50 HDTV Plasma TV
The only color I have on my tv is green. How do I fix this problem
mcid1515,
If you have an older set you probably need to turn up the screen drives on the red and blue guns. The largest part of the color signal is the green with red and blue much less. If the gun drives put out less as they age, and they will, periodically the screen drives need boosted. I have a tip at
http://www.fixya.com/support/r6814105-adjust_screen_drive_crt_projection_tvs
This will walk you through the process of setting the screen drives.
Thanks for using FixYa and for the great rating.
hardrocko
Feb 28, 2011 | Hitachi 43UWX10B 43" Rear Projection...
What are the menu settings supposed to be at for the color, picture, what do I do if the color is not right, pickish and green
Go to tv menu go to screen setting turn screen contrast to the max and screen brightness half midway point like 55.Tv real old like around ten years?Watches alots daily like 6 or 7 hrs a day?The tv CRT-(tv tube) might be to old,the radiation colors guns R,G,B insisde might not work as well as before.Have a reset setting in the colors setting?Go down to that press that,to restting for the factory colors setting.Or tries add more blue,a bit less green and red,see how that turn out?
Feb 05, 2011 | Panasonic CT-32G23 32" TV
I have a red and green bar rolling across my screen
call HP case management 877-917-4380, tell them you want this fixed and be firm. They are being very helpful with my problem and keep sending parts until it's fixed , all free of charge with tech at my house
Dec 03, 2008 | HP PL4260N 42 in. Plasma HDTV
Sony KDS-50A2000 screen is in green tint
My Sony KDS 50 A2000 is 17 months old. Its the 50 Inch SXRD projection model. About two weeks ago the screen developed a green tint with cannot be tuned out, then a few days later the message began to appear on the screen that the bulb was nearing the end of its life and must be replaced.
Fortunately I have the Circuit City extended warranty.
I called and within just a few days a serviceman came out and replaced the projection bulb.
The Result: No change in the picture, the green tint remains on all channels, so I'm awating the next service call. Under the service warranty they have the option to repair or replace this set. If indeed this is the light engine (optical block) which I suspect and its going to cost $1,000 or more I may be looking at a new set.
When it works this is a great TV, but I have had three Sonys now including two other standard CRT models and now this one joins them in the junk heap, the other two also bit the dust after just about two years. Is it time to give up on Sony?
I know they have a class action suit on a similar model for this same problem. Caveat emptor
Jul 31, 2008 | Sony KDS-50A2000 50" HDTV
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
2 year old Samsung 50" DLP
Sounds like a bad digital board to me. Not too hard to replace in those models but, you do have to write down a few settings before replacing it. These settings are available in the service menu. Any questions let me know tvtek@msn.com
Nov 30, 2007 | Samsung HLN617W 61" Rear Projection HDTV
LCD TV picture is green
I just called Vizio and they said to unplug the TV, then physically hold in the power button on the TV for 2 minutes.
Nov 19, 2007 | Vizio L37 Television
Screen now has 3 small boxes in middle - one red, one green, one white
Its easy to fix and cheap. Check www.magnavoxhelp.com for chip kits.
Nov 28, 2006 | Philips 9P5534C 55" Rear Projection...
Samsung HLR5667W 56" Rear Projection HDTV Logo
277 people viewed this question
Jerry Greenberg
Jerry Greenberg
