Question about Cell Phones
Blackberry Device Software v4.60 for the Blackberry 9000 smart phone shows on display reload software 513 ?
Reload software 513
Due to the Java Virtual Machine (JVM) error, the device will not show a Connected state in the Desktop Manager. Proceed to reload the BlackBerry Device Software using the Application Loader. .
To Fix this problem,please go on this link to know the step by step procedure.
CLICK HERE
I hope you can fix this problem...
Jul 22, 2011 | RIM BlackBerry Storm 9530 Smartphone
It says Reload Software: 513
After the maximum number of password entry attempts is exceeded by supplying incorrect passwords, and the BlackBerry smartphone is restarted, the following error appears:
The BlackBerry® Device Software must be reloaded on to the BlackBerry smartphone
Steps how to reload can be seen in below website
http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB11320
Thank You
Jan 31, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
Reload software : 513 comes with my blackberry 8520 curve what can i do
i'd attempted 10 times USB pwd, and now my phone s/w was all whipped off. msg on screen is reload software 513, plz help. i'd just got my Curve 8520 3 days ago...
May 20, 2010 | RIM BlackBerry Curve 8520 Smartphone
BlackBerry Curve 8300 Smartphone: jun error 513...
Thank you for using Fixya1
Based on www.blackberry.com the error message you are getting is due to typing incorrect password for a couple of times (10 or more).All of the data and applications on the BlackBerry smartphone have been deleted.
The BlackBerry® Device Software must be reloaded on to the BlackBerry smartphone. For instructions, click HERE
Note: Due to the Java Virtual Machine (JVM) error, the BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to reload the BlackBerry Device Software using the Application Loader.
Sincerely,
stif_nec
May 18, 2010 | AT&T Blackberry Curve 8300 Smartphone
I had a "reload software 513" error and had to reload software to get my blackberry bold to work. Now when I talk with people they can't hear me.
Download the Blackberry Desktop Manager from https://www.blackberry.com/Downloads/entry.do?code=A8BAA56554F96369AB93E4F3BB068C22, after downloading run the setup and after completing this step. Connect your blackberry to your computer and open the BDM (Blackberry Desktop Manager). The application would recognize your blackberry, when it shows that your smart phone has been connected, you can now run the software. Make sure your computer is connected to the internet.
Run the software and allow it run. This process may take few hours to complete once done it would automatically reboot your phone and you are good to go.
Thanks
Apr 08, 2010 | RIM BlackBerry Bold 9000 Smartphone
Reload software 513 for blackberry storm
I'm not too sure if all your data will still be there. But you can fix this yourself. You should be able to reload the device software with the Blackberry Manager.
Aug 29, 2009 | RIM BlackBerry Storm 9530 Smartphone
How do i reload software 513 for my blackberry storm.
What you need to try to do is reinstall the blackberry OS (operating system) on your device.
Assuming you have verizon
First install Blackberry desktop manager it should be in the CD that came with the phone.
If you can't find it download it https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=5E695511C1F9656B8E3E63DAB060F469
Then download the OS software for your phone http://vzw.smithmicro.com/blackberry/download.aspx?ct=personal"
Install it
Connect your phone to your computer and start Desktop manager
Click on application loader, on update software click start, click ok on USB pin selection.
when you get to the device backup and restore options, click settings and make sure backup options box is unchecked and device data boxes are both checked, click ok, click next, skip the email signup stuffs,and finish.
After the software is installed the phone should boot back up
Jul 13, 2009 | RIM BlackBerry Storm 9530 Smartphone
Reload software 513 error
After typing an incorrect password ten times and restarting the BlackBerry smartphone, the following error appears:JVM 513
All of the data and applications on the BlackBerry smartphone have been deleted and The BlackBerry® Device Software must be reloaded on to the BlackBerry smartphone (Due to the Java Virtual Machine (JVM) error, the BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to reload the BlackBerry Device Software using the Application Loader)
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 and 4.6, perform the following steps:
1) Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
2) Double-click Application Loader.
3) Click Add/Remove Applications.
4) Type your BlackBerry smartphone password and click OK.
5) Select the check boxes next to the names of the applications you want to load.
6) Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
7) Click OK.
8) Click Next > Finish
9) When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager.
Apr 10, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Need to reload software 513 blackberry
the Application error 513, reset message says that the device OS is toasted and needs to be rebuilt. In order to do this, you need to have Blackberry Desktop manager on your computer, your data cable, and a download for your device software. Either from blackberry or your carrier. The easiest method is to download and install the device software. Once it's installed, launch desktop manager and plug in the phone. If the phone is detected, you will be prompted to update. Follow the prompts. If not, you will have to do it the hard way. open command prompt (start>run>cmd) and goto C:\program files\common files\Research in Motion\Apploader Then choose Loader /NOJVM That's going to rebuild the blackberry.
Mar 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
JVM ERROR 513 BLACKBERRY 8310
JVM 513 indicates all data and application on the device have been deleted. To restore, you need to reinstall the Blackberry handheld software and restore the data from the backup file if you have it on your computer. To reload the software, you will have to connect the device to the computer and run Blackberry desktop manager and then application loader. In case you do not have thse software on your computer, check with your service provider and they will have the software available for free download on their website.
Nov 28, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
Cell Phones Logo
60 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
