Question about Cooktops
Cracked glass of Westinghouse silhouette Kitchen Cooktop
I accidentaly left an empty saucepan for 20 mins in mid temparature and the glass cracked. Is there any chace to change it or would i have to buy a new one? Could you tell me how much it could cost?
Thank you very much!
    Problem Solver:
  • 14 Answers
Bugger !
Price is model & country dependent.
Usually, it is easily be replaced. Lift out hob, keep right way up. Unscrew surround screws & lift glass off the base & guts. put new one on.
Posted on Dec 12, 2009
Can the glass of a whirlpool cerano hob suddenly crack?
You didn't need 'red hot' to simmer. When you got it red hot, and then put the pan on it, the pan sucked the heat out of the ring to fast, and caused stress in the glass causing it to crack. Tops are meant to be used the way you used it. Your fault I am afraid.
The top can be replaced.
Sep 19, 2016 | Whirlpool 30" Schott Ceran Surface...
Glass cooktop cracked
Glass cooktops can be removed/replaced with the aid of two small screwdrivers. Gently go around the outer rim using the two screwdrivers like tyre levers don't due too much pressure and it will generally lift quite easily.
Mar 23, 2014 | Samsung NE595R0ABSR/AC 30-in Smooth...
I need a replacement glass top for my Thermador CEP 365/CET365 cooktop. It is cracked but works fine. Where can I get this?
contact the service agent for the brand to see if a replacement glass is available
in reality you are not required to replace the glass as glass breaks in normal use and is out of your control and in renters terms comes under fair wear and tear
Dec 21, 2017 | Thermador 37 in. CEP365 Electric Cooktop
My glass cooktop has cracked across the top left corner. It has created a triangle, about 1-1/4 inch on each side. Is this a flaw in the glass?
most of the time for this to happen something would have had to been dropped or excessive weight on the unit ... it is possible over time the unit had a unseen hairline crack and the heat has caused it to become worse... the glass for these units are ridiculous in cost but can be repaired...
several online sites sell parts.... a few reputable companies are
www.sears.com
www.apdepot.com
www.repairclinic.com
Jan 21, 2011 | Whirlpool GJC3034 Electric Cooktop
Glass cooktop has cracked in two places
sounds like a stress fracture is your cooktop supported well
Sep 20, 2009 | Jenn-Air 35 in. JGC9536 Gas Cooktop
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Cracked Glass Top
I not know of any means of repairing same (maybe the system used to fuse auto glass) but if you want to replace it try repairclinic.com Item 935927 or 948440 $216/$227
Aug 27, 2008 | Jenn-Air JED8430 Electric Cooktop
Glass top
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
Jul 10, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Glass cooktop keeps cracking in same area
The cooktop box has a metal flange. Make sure the cooktop when dropped into the countertop is resting on ther metal flange and not the glass edge by itself. If it rests on the glass alone the weight will cause the glass to crack at some point in time.
Dec 20, 2007 | Cooktops
Cooktops Logo
310 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
