Question about Samsung WF206ANS Front Load Washer
Not spinning or draining Samsung front load wf206ans/xac
    Problem Solver:
  • 14 Answers
Won't spin if it hasn't drained. Most probably a blocked/jammed pump impellor. Manually drain it from the lower drain pump (by side tube if that model has one, or slowly into a shallow pan. Remove cap completely & check for things jamming pump.
Posted on Dec 12, 2009
SOURCE:
Error message of
That means overflow. There is too much water in the drum. Turn the unit off and it should drain. If not then it might be a sensor that is bad.
Dec 03, 2013 | Samsung WF206ANS Front Load Washer
A "nd" code displayed,
How to fix a Samsung Washer nd washer error code. You can make this repair your self and in most cases without parts.
Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain.
When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front.
If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise.
If the front panel does not have the access panel the washer will need to be slide forward.
With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible.
Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Put the washer back together and test for proper operation.
If the error code comes back this means that the pump is clogged again or the pump has failed and would need to be replaced
Feb 27, 2013 | Samsung WF206ANS Front Load Washer
Samsung vrt front load washer will not spin out, ( not working)
I have the same washer and mine wouldn't spin out all the way sometimes leaving the clothes very heavy and wet. My problem was that the drain hose from the washer that you put inside your drain pipe had created a suction preventing it to drain properly. It might be worth checking. I know for forking out so much money on the thing it sure can be finicky.
Apr 18, 2012 | Samsung WF206ANS Front Load Washer
Service (repair) manual for Samsung WF203ANS/XAC
You have this listed in the Projection TV area--try posting a new question in the major appliance area---if you post the model number a expert in that area MAY help you or suggest how to get what you want.
Apr 06, 2012 | Televison & Video
I have a wf206ans machine and today i had error code that looks like (be) or (he) i cant find the manual for this machine .this code appears on all cycles for the machine washing or spinning only . any...
The manual for the WF206ANS is available here: http://downloadcenter.samsung.com/content/UM/200701/20070131100335625_WF317AA_XAA_02291A.pdf . The table with the code list is on page 22 of the pdf (page E-3). A bE error is a motor speed sensor error. If the code reappears when you restart the cycle, then the washer needs service. For other codes or for service, call 1-800-726-7864 (1-800-SAMSUNG).
I hope this helps.
Mar 27, 2011 | Samsung WF206ANS Front Load Washer
I have tried everything, but my front loader (Samsung J845) door won't open. I can't get a repair person until Monday and the clothes trapped in there are rotting. Have only had machine for two years and...
Remove the plug and see if the program can be activated. If not try to reset the program, if there is a failure to shut off the door lock it is possible that the program controller has failed.
If so you will need to first of all drain off the water in the tub by removing the drain hose. Please make sure that the washer is kept out to drain or there could be flooding inyour room. Once the water has drained use a long head screw driver to manually release the lock of the door.
You might have to use agood light to see the latch to release the lock.
Nov 03, 2010 | Samsung WF206ANS Front Load Washer
Wont pump out water after wash cycle
three possible solutions. Internal filter is blocked. Motor brushes need replacing. Pump has stopped functioning. Check pump on drain cycle if not working check for broken wires or you might need to replace.
May 24, 2010 | Samsung WF206ANS Front Load Washer
I keep getting a nf error message. what is this
water fill valve screens may be plugged filling too slow or valve may be bad or is one of the hoses turned off
Dec 31, 2009 | Samsung WF206ANS Front Load Washer
Samsung WF206ANS Front Load Washer Logo
1,268 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
Paul
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
