Question about Master Heaters BLP375AT
Master space heater cutting out
Hi
I have a master space heater (small 20kW) model. It was running fine until a week or so ago. It started to cut our after a five minutes, then three, then one and now after a few seconds. There is no thermostat cut off on this model. It has a photo cell cut off, which sits at the back of an inch and half long rubber tube. The photocell looks perfectly clean, and I have not touched it. The only thing that has changed is new fuel. I bought a 25 litre can of heater fuel which is basically diesel wiht a 61C flashpoint. Any ideas folks?
  • 22,326 Answers
Last time i had problems with one of these doing a similar thing ,and this was the arc that ignites the fuel .the carbon rods that arc across to ignite the fuel,used to run them on red diesel so i think fuel is ok ,so either the carbon rods need adjusting closer together or the high tension coil is playing up .One or the other if not both things can cause this type of heater to play up,same principle as my steam cleaner which i fixed with a length of metal car brake pipe to replace one of the carbon rods that was burnt out
Posted on Dec 12, 2009
My tpi 305 runs for 5 minutes then dies and wont restart why
have you checked the oil pressure sending unit switch?
Dec 04, 2012 | Cars & Trucks
My homelite chiansaw HCS3335 runs fine for about five minutes and then just cuts out and will not start until it has cooled down what is the problem
hello,After it stalls take the fuel cap off and put it back on and see if it starts,maybe the cap is bad or clogged and not letting air in to equalize the pressure of the fuel being used in other wards a clogged vent, this is a small thing but a big problem,,hope this helps, ``
Feb 20, 2012 | Garden
Have a master 165,000 btu turbo heater it always starts and runs but sometimes it will run for 5 minutes 7 or 10 no matter where i set the built in thermostat,any tips ????
I would start by checking the fuel filter form the tank to the nozzle. If this is getting dirty the heater will slowly start loosing the red glow on the nose cone until the until shuts down.
Normally if it sets for a few minutes it will start and run again.
You can order a filter replacement kit that has all of your filters included.
Nov 03, 2010 | Master Heaters Master B115DT 115,000BTU...
My heater starts fine and runs maybe 5 minutes then shuts off. Any clue where I should start looking?
Here is a tip about troubleshooting Torpedo Heaters
Reddy Heater - Troubleshooting Torpedo Heaters
heatman101
Jan 12, 2010 | Milwaukee Tool Master Heater B200 Series...
Clutch works fine until. except that it doesnt
I don't have that shop manual, but the slave cylinder looks like a small brake master cylinder and is on the firewall on the driver side.
Check to make sure floor pan is not split by slave cylinder. Some had weak floors that needed reinforcing. Ford had a kit.
Otherwise, replace slave cylinder. tascafordparts.com sells at discount.
Please rate as fixya if this solves your problem.
Report back and good luck
Mar 05, 2009 | 1989 Ford F 150
Frigidaire built stacked washer and dryer
There is a thermal cut off on the motor. when it overheats it will trip and not start until the motor cools down. Replace the motor to solve the problem.
Jan 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
Master Heaters BLP375AT Logo
283 people viewed this question
Top Master Heaters Heating & Cooling Experts
T bone 1963
Gil Shultz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
