Question about Epson Stylus C40UX InkJet Printer
Can't locate the 4 screws that hold on the cover
I have a similar problem with my epson stylus c4oux. I can't locate the screws or whatever that holds the cover on. If you tip it upside down the ink runs out, but I have looked under it without turning it upside down and I don't see any screws, none on the sides either. Where the heck are the darn things. I'd appreciate your assistance.
Carol
  • demon12 Apr 08, 2008
    ican't find the screws ether
They are not screws there are latchs
Posted on Apr 08, 2008
How do i change an ink cartridge out of an epson stylus C4OUX
use a user manual or you can browse in the net thers a step by step procedure that can help you..
May 09, 2011 | Epson Stylus C40UX InkJet Printer
Cant print anymore print counting is almost full. how to reset count
try this
Manual reset methods several EPSON Stylus Color. Actually there are two methods to reset epson printers counter, that is using software resetter such as adjustment program or SSC service utility or using manual by combination pressing button on the printer. If Reset using software resetter you can follow the way of usage the software but sometimes software resetter for the printer is not available. The only way to reset the printer if software resetter not available you can use manual reset.
The Following manual reset for some EPSON Stylus Color Printers:
1. EPSON Stylus Color
Pressing and holding ALT+FONT+LOAD+PAUSE buttons combination
press POWER button
Release all buttons
2. EPSON Stylus Color 300
3. EPSON Stylus Color 400, 600
Pressing and holding LOAD/EJECT and CLEANING buttons
press POWER button and hold it until you will see blinking INK OUT and PAPER OUT leds
Release all buttons
In 2-3 seconds time press LOAD/EJECT and CLEANING buttons again.
4. EPSON Stylus Color 440, 640, 740, 460, 660, 670, 760, 860, 880, 1160
press POWER button and hold it until You will see blinking INK OUT and PAPER OUT leds.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button, until all leds will blink.
5. EPSON Stylus Color 680
Pressing and holding LOAD/EJECT and CLEANING buttons,
In 2-3 seconds time press and hold LOAD/EJECT button, until all leds will blink.
6. EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons
press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
7. EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led
Release all buttons
8. EPSON Stylus Color 800, 850
Pressing and holding LOAD, CLEANING Color and CLEANING Black buttons
In 2-3 seconds time press and release CLEANING Color button, You will see leds blinking.
9. EPSON Stylus Color 900, 980
press POWER button, You will see blinking INK OUT led
Release all buttons
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
10. EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons
turn on printer.
Mar 17, 2011 | Computers & Internet
Change ink cart
well lift the cover up on the from you will see the cartridges right in the center at the bottom. their will be plastic clips holding them in push on them and that will release the cartridge
Jan 23, 2009 | Epson Stylus C40UX InkJet Printer
Resending
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Epson Stylus C40UX InkJet Printer
Need help intalling epson stylus c4oux on my apple
Hi
Go to this link and download the correct driver for your operating system click HERE
Hope this helps
Jan 02, 2009 | Epson Stylus C40UX InkJet Printer
Epson i880 Waste Ink pad location
try this plz dont for get to rate
1. Turn the printer off.
2. Hold down the ink and paper buttons, and turn the printer back on.
3. Within a few seconds, the paper light will start flashing quickly. When it does, let go of both buttons.
4. Within 3 seconds press (and hold) the ink button.
5. Hold it until all three red lights start flashing (about 10 seconds).
6. Let go of everything.
7. Turn the printer off, and back on.
Dec 07, 2008 | Epson Stylus 880 InkJet Color Printer
Epson 760 Problem
I found this procedure to work for the Epson Stylus 760 printer. The error is indicated by all four lights on the printer flashing and appears to be caused by the internal counters of the machine being exceeded. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
1) Turn off your printer, ensuring that the print head is at its home location and locked in place as normal.
2) Remove the four screws securing the top cover two at the rear and two at the front under the lift up cover and lift the cover off.
3) Remove both ink cartridges.
4) When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer’s power switch was ‘on’ - switch it off and return to step 1.
5) Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down.
6) When the paper-out LED flashes, release the buttons.
7) Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button).
8) The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
9) Insert the cartridges as normal and replace the cover.
Mar 13, 2008 | Epson Stylus Color 760 InkJet Printer
Epson Stylus C40UX InkJet Printer Logo
27 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
