Question about Refrigerators
Sears kenmore side by side, 25 cuft, freezer works ok, refrigerator side does not cool,
    President:
  • 1,891 Answers
Look for ice on back of freezer wall or a fan in freezer that is not going . frost on back will restrict air flow to fresh food area / and bad fan will do the same .. hope this helped . mm
Posted on Dec 12, 2009
I just purchased a kenmore side by side refrigerator/freezer and its been 24 hrs and the refrigerator part is still not cooling. Is this normal with this brand?
No, check the thermostat setting and see if it is set where you want, it may be in the off position. I am assuming the freezer is OK. If that fails contact sears for warrenty repair or replacement.
Aug 24, 2014 | Refrigerators
My kenmore elite side by side fridge not cooling, but freezer is working ok, please help
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 11, 2011 | Refrigerators
My Kenmore Elite 25' Bottom Freezer Refrigerator, the lower freezer portion is working mainting a -3 degrees but this morning the upper refrigerator portion is not, what would be some likely problems to...
I guess you are talking fahrenheit temperature?
This is ok for the freezer.
The problem could be;
\ ducting blocked restricting air flow
\ evaporator fan not working
\ ice build up on the evaporator blocking air flow
You will need to get a technician to look at this problem for you
Mar 25, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Freezer works, Fridge doesn't
The defrost timer inside the fresh food compartment is most likely the problem. Need to turn the timer slowly clockwise until compressor stops. I should remain off for about 25 minutes. During that time the freezer should be in defrost. You may be able to open the freezer door and hear the crackling and sizzle of the defrost taking place. If the timer does not restart the refrigerator after 25 minutes the turn the timer clockwise again until the compressor restarts. Number 6 in photo below is the defrost timer. The replacement timer part number is 482493. Here is a photo. Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Aug 19, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My freezer cools properly but my refrigerator is not staying cool .its kenmore and bought from sears 2004 $1000. side by side refrigerator
Quick temporary fix - defrost the freezer (inside frezer lower back) it is probably full of frost/ice - this prevents air flow and therefore no air enters fridge side. common failure due to bimetal defrost thermostat failure ($20) - replace this part for a permanent fix - also advisable to swap out the defrost timer at same time
Aug 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore refrigerator not cooling
You will need to replace the heating element, if it looks blacken, then it's not good. When good, it's a clear glass tubing with a coil that heats up. Call Sears for parts.
Jul 20, 2009 | Kenmore 50522 / 50524 Side by Side...
I have new fridge by kenmor( Sears) by side doors. Freezer is ok but the fridge (right side or the fridge) side is not cooling. There is no air blowing through the openings in the cooling side.The fen...
check if there are still packing tapes holding the flap of the opening. these dampers could also be stuck closed.
but the best thing to do is wait for the tech from sears, since it is brand new. it is still under warranty.
tnx 4 using fixya,
drcool
Oct 21, 2008 | Refrigerators
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
