I have a Linksys WRV200 Router that constantly drops the wireless signal. I upgraded the firmware to 1.0.39 as was suggested by many, then performed the factory default reset, reinstalled all my custom settings and still have the same problem. This problem is with the same model router at three different locations. Is there a fix or what is a suitable replacement router?
  • diego361 Dec 12, 2009
    On this particular network I am using a Dell Inspiron B130
    running Windows XP Professional and Norton Internet Security. On
    another network everyone's laptops disconnect constantly and that also
    has Norton Internet Security. A third network with the same
    router also has Norton Internet Security. Since that is the
    common denominator is that the problem?
  • 4,281 Answers
Access your router settings and change channel type to 3 or 4 or 11.
Then save settings and restart router.
Channel type is very important in wireless signal Above 3 works fine in wireless.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Dec 12, 2009
    Guru:
  • 212 Answers
Hi Diego
You have not listed your PC/Laptop and OS Specs here, so i am providing you some generic tips to try resolving this issue
Try the following steps to see if it helps to resolve this issue
1) Try operating your PC/Laptop to bare minimum processes running in background and disable any virus scan or indexing feature running on your machine if you have a windows OS, check how your connection behaves.
2) Does your connection automatically try to connect again after it drops and get connected again, or do you have to manually do a router restart to get it working again, or do a connection repair in windows, both these situations have different set of solution so check if you can provide additional info on this.
3) Try disabling the WPA security feature and see how the connection behaves again, set router network mode to G-only as well as trying
mixed mode.
4) Check for any interference of bluetooth devices or microwave or a cordless telephone with the connection.
5) Try changing the wireless security on your router to WPA instead of WEP. Make sure you change the settings on your wireless card also to match the router settings if you are using a laptop.
If the above steps do not help, you may seek replacement from LINKSYS.
Regards
KreativeGeek
The router often looses wi-fi signal and dhcp gives wrong address ( exemple: 169.164.....)
Here are some links for things to look for and check for you wireless connection isues:
If the links do not work just copy and past them in to you browser. If you dont have a internet connection available I have listed them below the links.
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=172c1dae41534ddd818c560b60c7c230_4029.xml&pid=96&slnid=16
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=efc03a44a5bb47bd804cf4d0eb3015c8_Top_Causes_of_Intermittent_Wireless_Connection_to_a_Linksys_.xml&pid=96&slnid=16
Top Causes of Intermittent Wireless Connection to a Linksys Router
There are three key reasons that may be cited why the wireless connection between your Linksys router and your computer is intermittent or is experiencing timeouts.
i. You have a low signal quality received from your wireless router.
ii. You are experiencing signal interference from other wireless devices.
iii. Your router's firmware needs to be upgraded.
You have a low signal quality received from your Linksys wireless router.
The location of your wireless router with respect to your computer greatly influences your connection to the wireless network. For a better signal quality, it is ideal that the wireless router is placed in a central spot of your house or on a location free from any obstruction blocking its range.
To determine the signal quality received from your wireless router, you must connect to the wireless network first.
NOTE: For instructions on how to connect wirelessly to your Linksys router, click here. If you're using a Mac computer, click here.
Once connected, check the signal strength received by your wireless adapter or Airport for Mac users. The recommended signal strength should be closest to full bars to have the best connection possible.
The frequency used by your router's wireless network may be 2.4 GHz, 5GHz or both. Some devices may also be using the same frequency and this causes the interference to the wireless network of your Linksys router. The most common examples are cordless phones, microwave ovens and baby monitors. Another possibility of frequency interference is that there may be other wireless networks in the area. Your frequencies may be conflicting with each other.
To solve this, turn off the device that is possibly causing the interference or relocate your router away from it. Another solution is to change the current wireless network channel which is set in your router's settings. For instructions on how to do this, click here.
If you are having unstable connection and have confirmed that the previous causes are irrelevant, then you may have to upgrade your Linksys router's firmware. For instructions on how to do this, click here.
Encountering Intermittent Wireless Connections Using a Router
Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
  • 2.4 GHz interference: Your router may be operating on the same frequency as your cordless telephone system (or even your neighbors'), or other nearby equipment. Try to change your router's channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
    Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
  • Customizing Wireless Settings of the Router
    Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. We suggest changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
    1)To change the router's SSID or the wireless network's name, click here.
    2)To change the router's channel, click here.
    3)To enable the wireless security on the router, click here.
    NOTE: If the wireless connection remains unstable after performing the steps above, it could mean that your firmware is corrupted. For instructions to reload or upgrade firmware, click here.
Dec 14, 2010 | Linksys WRT120N Router
Since getting a new Dell laptop and Linksys E1000 (also have HP desktop), my internet connection keeps dropping (no problems ever before)- sometimes I can stay online for 2-3 hours or it can go in 15...
we need to first figure out whether it the modem or the router which is dropping the connection.
Please connect one of your computer directly to the modem, by pass the router and access the internet. If the connection drops then its the modem which is dropping the connection and you need to contact your isp to check it.
If the internet works fine directly with the modem then its your router which is dropping the connection. To fix the router we can upgrade it firmware.
To upgrade the firmware please visit the link below;
http://homesupport.cisco.com/en-us/wireless/linksys/E1000
Note; If you are not comfortable upgrade the firmware then don’t do it. If not done properly then it can damage your router.
Rashish
Aug 16, 2010 | Linksys Wireless-G WRT54G Router
Router keeps dropping connection
Solution for wireless dropping issue or connectivity issues
*Change channels on the router from1,6,11 or 9(rarely works) *Change Channel width 20 or 20/40 MHz *Keep other radio signal emitting or wireless devices away as possible *Change security types *Change Antennas position *Upgrade the firmware
May 15, 2010 | Linksys Wireless-N WRT150N Router
Signal strength is dropping, had excellent signal before now down to very good to good.
You can try first changing the wireless channel on your router you can follow the steps from this link....
but after that still having the same problem you need to do a firmware upgrade on your router....you can get the latest firmware from Linksys web site....
http://www.fixya.com/support/r3791429-change_wireless_channel_linksys
Jan 03, 2010 | Linksys Wireless-G WRT54G Router
My wrt600n start playing with my speed it change it every minute from 0.3 Mbps to 14 Mbps. how i can fix it
A couple of suggestions.
First, check your signal strength. The further you are away from your wireless router, the less signal strength you have. The router compensates for this by operating at a lesser bandwidth.
Next, make sure you don't have something interfering with the wireless signal. Microwaves and cordless phones are two major culprits for messing with the 2.4Ghz signal on a "G" router.
Last, check for the latest firmware from Linksys' website. Sometimes there are buggy things that just need to have a firmware upgrade to fix. Consult your product manual or the Linksys tech support site for firmware upgrade instructions.
Aug 29, 2009 | Linksys WRT600N Wireless Router
Keep losing the signal. appears that the power
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 25, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Wrt54gx2 dropping out, loosing both wired and wireless signals
Try to upgrade the firmware of the router.Download firmware file from http://www.linksysbycisco.com/US/en/support for your model and open 192.168.1.1 Leave username blank and in password type admin click on administration and then on firmware upgrade.Browse and select the downloaded file and upgrade the firmware.
Apr 12, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Laptop driver needed
You dont need a driver for the wireless router. If your laptop can recieve wireless signal(from a wireless router) all you need is an active internet connection, configure the laptop and router to distribute the internet, you're good to go.
If your laptop cant recieve a wireless signal from a wireless router then you might need a USB Wifi Dongle.
Apr 06, 2009 | Linksys Wireless-G VPN router with...
Linksys rangeplus drops wireless connection ever 5-10 mins
Thanks, Joe
Feb 19, 2009 | Linksys Ultra RangePlus Wireless Routr...
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
